  • Replies 81
is ur line silver with a big nismo sticker on the back window??
looks pretty stock from the outside? Stock wheels but with a GTR style rear wing?
if so i live about 1min away :) across the rd from safeway
Originally posted by devlsh
Im from northen suburbs (Preston).
Inark:  Where abouts is Dingley??  What other suburbs is it close to??
cheltenham, moorabbin, keysborough, noble park
Originally posted by Viper180
More ppl from Dingley. I noticed some dude round the corner from me must have just got his R33 the other day. Was out the front of his house looking at it with his mates, theni saw him taking his oldies for a spin in it. hahah
hehe...
i seen a nice red 32 round the corner from my house.... havent noticed it since... decent rims and a slight body kit.... dunno if its a mate of theirs or someone in the area just got it... must have seen mine and wanted one right away! :)
do any of you guys live around brady rd/carlton rd dandy?? i was comming home from a 'small' cruise of my own uncomplianced hehe on fri night, and was comming down a side stree and REALLY slowed down when i saw another line(white i think-it was late) backing out of a driveway......
Was it a White Skyline??
Andrew
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
