As my title states I have a question about upgrading the valves on my RB25DET NEO engine.
I had a timing belt mishap that decided to bend all 24 of my valves so I am needing to replace them.
I brought the head to a machine shop who ordered Ferrea NEO valves (par numbers F1935P & F1933P) and upon arrival they were different than the OEM valves that were in the engine.
Keep in mind I have not seen either of these valves in person yet.
Supposedly the OEM valves are 6mm at the stem and then about 1cm from the top taper down into a 5mm stem. But the Ferrea valves don't taper down - they just stay 6mm the whole length of the stem - thus is requiring me to replace all my keepers, springs, etc (everything to do with the valves) resulting in a MUCH higher cost than anticipated and much higher cost than I can afford.
Essentially what I am wondering is if someone has replaced their valves with Ferrea ones and kept all the other OEM components such as keepers, springs, etc. and had it work just fine.
I am starting to wonder if this shop is just trying to get more money out of me.
https://www.sau.com.au/forums/topic/478053-rb25det-neo-valve-questions/
1 minute ago, GTSBoy said:
I have vague memories of people needing to use Ferrea's retainers etc. Shouldn't need springs though.
I think I am going to try and call them when I get off of work if they are still open and clarify...
Otherwise I think I am just going to go back with OEM valves and save myself the thousands.
