Hi all, so i ordered an npc organic clutch and flywheel, rang up Nissan to see if they had any genuine oil for manual 5 speed gearbox, they said the stock oil is castrol vmx 75-80 or vmx 75-90. I am now confused, which exactly is the standard one and what is the difference between the two? I know theres previous threads discussing using redline lightweight shockproof, but from what ive read, this is for worn synchros? I cant tell the exact condition of my gearbox, but it shifts into every gear smoothly, so thats why i was thinking of using the standard oil, unless its suggested otherwise?
https://www.sau.com.au/forums/topic/478124-r34-gt-t-gearbox-oil-differences/
75-80 refers to the viscosity of the oil in "winter" and "summer" respectively. It's a multi-grade oil that changes its apparent viscosity with temperature. When its cold, it acts as if it's a little thinner (the 75) and when it is hot it acts as if it is a little thicker (the 80).
The other oil has a wider difference between cold viscosity and hot. So which one you use might depend on where you live and/or how the car is used. If you live in a cold part, you might use the 75-80. If you live in a hot part or the engine and gearbox get driven hard for extended periods (and so dump a lot of heat into the oil) then you might choose the heavier oil.
As you say, if your box is in good nick, there's no need to put shockproof in it. Just use the VMX.
Edited by GTSBoy
bluddy typos
  • Like 1
The other oil has a wider difference between cold viscosity and hot. So which one you use might depend on where you live and/ore how the car is used. If you live in a cold part, you might use the 75-80. If you live in a hot part of the engine and gearbox get driven hard for extended periods (and so dump a lot of heat into the oil) then you might choose the heavier oil.
Ah beautiful, just what i was looking for. Yeah the car is used mostly as a weekender and i do a few track days a year in it, so looks like 75-90 is definitely the way to go, thanks :)
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
