Anthony1016 Posted August 8, 2019 Share Posted August 8, 2019 Hi All, Thinking of getting into the drift scene with an R31 however I have searched the forums and come to no definite conclusion about RB20DET/ET vs RB30ET. Would it be better to buy an RB20DET/ET skyline or turbo an RB30E? I understand at the end of the day not project car is ever cheap in the long run but I'm trying to go for the most budget friendly option. Cheers. Link to comment https://www.sau.com.au/forums/topic/478202-budget-drift-build-rb20detet-or-rb30et/ Share on other sites More sharing options...
KiwiRS4T Posted August 8, 2019 Share Posted August 8, 2019 RB30/25 will be miles better. You can do it on the "cheap" stock everything except rings, bearings and small end bolts but it will still cost for the twin cam head, ecu and the other bits and pieces. 1 Link to comment https://www.sau.com.au/forums/topic/478202-budget-drift-build-rb20detet-or-rb30et/#findComment-7913027 Share on other sites More sharing options...
GTSBoy Posted August 8, 2019 Share Posted August 8, 2019 30 over 20 EVERY DAY. Link to comment https://www.sau.com.au/forums/topic/478202-budget-drift-build-rb20detet-or-rb30et/#findComment-7913028 Share on other sites More sharing options...
The Bogan Posted August 8, 2019 Share Posted August 8, 2019 Dirty 30 Link to comment https://www.sau.com.au/forums/topic/478202-budget-drift-build-rb20detet-or-rb30et/#findComment-7913031 Share on other sites More sharing options...
Anthony1016 Posted August 8, 2019 Author Share Posted August 8, 2019 (edited) 6 hours ago, KiwiRS4T said: RB30/25 will be miles better. You can do it on the "cheap" stock everything except rings, bearings and small end bolts but it will still cost for the twin cam head, ecu and the other bits and pieces. Cheers man, what would you estimate the total cost for parts roughly? Edited August 8, 2019 by Anthony1016 Link to comment https://www.sau.com.au/forums/topic/478202-budget-drift-build-rb20detet-or-rb30et/#findComment-7913051 Share on other sites More sharing options...
KiwiRS4T Posted August 8, 2019 Share Posted August 8, 2019 Really hard to say as many parts will be second hand so may vary according to your luck. If you can pick up a going RB25DET for $1 500 that could be the way to go. Then you will need a FMIC, figure out a way to tune it (could cost 2k alone) better injectors and fuel pump, the aforementioned rings, bearings and small end bolts, better clutch...assuming no labour except for the tuning you are at $5k at least. Try not to spend any money on non essentials like FF Plenums or aftermarket exhaust manifolds etc 1 Link to comment https://www.sau.com.au/forums/topic/478202-budget-drift-build-rb20detet-or-rb30et/#findComment-7913053 Share on other sites More sharing options...
Griffin Posted August 9, 2019 Share Posted August 9, 2019 Where are you located? I've got an rb25det neo engine, manifolds and bits and pieces at Newcastle if interested in having a look. Link to comment https://www.sau.com.au/forums/topic/478202-budget-drift-build-rb20detet-or-rb30et/#findComment-7913094 Share on other sites More sharing options...
Anthony1016 Posted August 9, 2019 Author Share Posted August 9, 2019 3 hours ago, Griffin said: Where are you located? I've got an rb25det neo engine, manifolds and bits and pieces at Newcastle if interested in having a look. I'm in Sydney but willing to drive for parts, how much were you looking for? Link to comment https://www.sau.com.au/forums/topic/478202-budget-drift-build-rb20detet-or-rb30et/#findComment-7913115 Share on other sites More sharing options...
niZmO_Man Posted August 9, 2019 Share Posted August 9, 2019 RB30ET, it's been done many times before. Just get it tuned properly with the supporting mods. Link to comment https://www.sau.com.au/forums/topic/478202-budget-drift-build-rb20detet-or-rb30et/#findComment-7913121 Share on other sites More sharing options...
Griffin Posted August 9, 2019 Share Posted August 9, 2019 18 hours ago, Anthony1016 said: I'm in Sydney but willing to drive for parts, how much were you looking for? Send me your pH number and I'll let you know what I have Link to comment https://www.sau.com.au/forums/topic/478202-budget-drift-build-rb20detet-or-rb30et/#findComment-7913175 Share on other sites More sharing options...
