Hi All,
Thinking of getting into the drift scene with an R31 however I have searched the forums and come to no definite conclusion about RB20DET/ET vs RB30ET. Would it be better to buy an RB20DET/ET skyline or turbo an RB30E? I understand at the end of the day not project car is ever cheap in the long run but I'm trying to go for the most budget friendly option.
Cheers.
RB30/25  will be miles better. You can do it on the "cheap" stock everything except rings, bearings and small end bolts but it will still cost for the twin cam head, ecu and the other bits and pieces.
  • Like 1
Cheers man, what would you estimate the total cost for parts roughly?
Edited by Anthony1016
Really hard to say as many parts will be second hand so may vary according to your luck. If you can pick up a going RB25DET for $1 500 that could be the way to go. Then you will need a FMIC, figure out a way to tune it (could cost 2k alone) better injectors and fuel pump, the aforementioned rings, bearings and small end bolts, better clutch...assuming no labour except for the tuning you are at $5k at least. Try not to spend any money on non essentials like FF Plenums or aftermarket exhaust manifolds etc
  • Like 1
3 hours ago, Griffin said:
Where are you located? I've got an rb25det neo engine, manifolds and bits and pieces at Newcastle if interested in having a look.
I'm in Sydney but willing to drive for parts, how much were you looking for?
    • The interesting part of tests like IM240 is they measure the exhaust output. But they never measure the gases going into the engine... Imagine doing the test in a densely populated city with higher CO2 levels around... Instant disadvantage...
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
