Gents,  as per the subject is it possible that i can be sent a Wolf 3D V4 base map to suit an RB25DET? Ive got an RB powered Patrol GQ and have just chucked in a Wolf 3d with a start up map, but would love to have a complete map to compare and have a play/tune with.  Would be really grateful if anyone can help with this :)
PS: Ive got 3" exhaust,  hi flow filter, PWR intercooler etc.
My email is [email protected]
https://www.sau.com.au/forums/topic/478211-wanted-wolf-3d-base-map-for-rb25det/
Hi mate, was hoping for someone to have a map that mimics the factory full map (my old factory ECU is not useable atm) or lightly modified map that I'll analyse/ compare in the wolf software before thinking to use. Purely to use the car for basic duties until getting full tune (5 weeks wait at Sabbadin etc).
Also have tried temporarily using two other Series 1 factory ecu's with no luck, the wolf however fired up straight away.
Fair enough, can't say I'd ever recommend blindly using someone else's tune but your call.
Where did this existing map come from?
You might struggle to find someone else with a wolf V4, pretty old and unpopular ecu these days. If you want a second set of eyes to look over your map, I'm happy to look at it and see if any red flags pop up.
Do you have a wideband O2 sensor?
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
