5 hours ago, NEO25T said:
Did you hold the intake cam on the hex with a spanner while removing/installing the cam gear?
If not it might be jammed advanced and could probably cause something like this
yes i did that remove it with a spanner in place to remove the vct gear
  • Replies 50
Posted Images
Last thing I can think of, my fuel map need adjusting after tightening the valve clearences but it still ran and idled
you know whats funny now.... i checked the cam specs card to see whats the clearance of tomei 262 should be and it fell within the range the clearance of it and i personally wanted it to be in nissan specs so thinking i have it at a tight valve when tomei requested it to be so without me even realizing it....now it have me wondering it can be really something else geeezzz :/
Ok buddies... i have finally got the time to check the timing and did a compression test and so far on the timing its on spot so far , the compression test showed the same value for the cylinders 2-6 of 125 but cylinder 1 was a bit lower but thats due to valve 1 of the intake being 0.011 when the others are 0.012.... so my last check is to do a proper smoke test.. what yall think?
2 hours ago, Ben C34 said:
Cam timing or ignition timing checked?
cam timing is on spot but havent checked the ignition timing...also what i forget to mention is that the compression tester took a while to build up the reading so it have me wondering that its looking like a valve seating issue... could be wrong ?
lolllll i came to harass my sau buddies once again..... finally took of the head saw nothing to really say A BIG issue.... Took some gas and put it on all 6 chambers of valves and all seems to be well sealed except for one but very slow .... so now am left to believe due to the shim clearance settings i got for intake and exhaust can be causing the problem...
Intake - 0.012(Nissan) Tomei Requires - 0.018
Exhaust - 0.019(Nissan) Tomei Requires - 0.015
what i currently have is the intake side of nissan and the exhaust side of tomei so am wondering to have the intake of tomei to see if it makes a differences .....
There is no way that slightly tight clearances can cause NO vacuum. Slightly less vacuum perhaps. But not none.
You definitely have something very weird going on, and in my experience of these threads, it always turns out to be something that no-one could have guessed.
ok let me say again..... its very hard for the engine to idle at 1000rpm so high rpms it idles but with no vac... if it trys to go 1000rpm its gonna cut off sure.... did a compression test and it took long for the results to build up wasnt like the first pulse it jump to a 60-90psi reading and then settle to another high number...
Just now, GTSBoy said:
Let me state again.....how the hell can slightly tight clearances cause the effect you're seeing? It's just wrong to think that they can. The problem is elsewhere.
am moving away from the "tight clearance" cause i saw it still wouldnt cause that issue, what i  really wanna know what IF the clearance settings i posted a little while would cause a change in overlap .... am not no genius in this cause currently search results is limited to my question so i hadda fetch from all over and then put it together to see if it makes sense .... Timing correct,did a smoke machine test no BIG leak, compression test done(but slow build up)
22 hours ago, GTSBoy said:
Will change overlap, but only by a tiny amount.
I'm thinking that something really big is wrong and you should take it apart. This is generally how these threads go.
Well i did and so far i havent seen anything wrong,valves are sealing properly..... so just for a piece of mind i did the intake clearances to tomei spec and so is the exhaust.... now its just to time the engine and am not even gonna start just run a compression test again and see whats popping...am starting to wonder maybe the engine was just a tooth off and could of been part of the issue even doh i checked a million times   if that doesnt work welllllllllllllll idk lol
And yes i held it in position in removing and installing.This might be my last bet.. If its stuck open it will create much more overlap = low vac. Correct me if am wrong.
How can i tell if my vct is stuck.....
Still won't cause what you are experiencing.
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
