And the battle continues........
Timed the engine on points,ran a compression test again still did the slow build up starting to think that compression tester is maybe defective or ill need to try another one or try that same one on another engine to confirm... havent start the engine to see if its still doing the low vac issue...
  • Replies 50
Posted Images
5 hours ago, NEO25T said:
Well fire that puppy up, you might have fixed it lol
Is your idle control plugged in properly, if thats not opening to keep the motor running, rpm will be down as well as vacuum
illl start sometime this week.. just need time to finish mount up other components.....am running no IAC/Idle control.....
This is the slow compression build up i was referring to
How did you lap the valves, and why?
Do a leak down test or at least out air into the cylinders, I reckon you have valves not Sealing correctly. That's my current guess anyway
when i pulled down the head while communicating with you guys i did a kerosene leak down to see if any vales were leaking and if there was any only one or two which was slight on the exhaust side. Intake had no sign of leakage and i did all valves with the head turn over and the kerosene settle on the valve based..... so am trying to get another compression tester dont have access to a leak down tool.....
Reason why i lapp the valves well more fine on intake and coarse and fine on the exhaust is cause the last two valves of the exhaust had a slight bend so all 12 valves were lapp over on the exhaust which change the clearance i believe....and after that is when this issue was shown..... I already change the clearance to tomei spec of 0.018 thou on the intake... i may/might start the engine and see if what i did made any difference...Engine time on points am only left to believe either the vct might have a play in this but i doubt
all that was done to the head when taken off was - Replace exhaust #11 and #12, Tomei 1.2 head gasket,stock head bolts torque to nissan specs,changed valve seals ,lapp intake with fine and exhaust with fine and coarse...Thats about it....
Edited by DTT_Eruc
Have you done a wet compression test at all?  I'd like to see a dry then a wet test and see if there is much difference.  I realise that the focus is on the head and valves being the issue [and I tend to agree], but a wet comp test would confirm this.
    • Well, if it wasn't a GTR I'd say that killing an RB is a perfect opportunity to put in a proper engine. In your case, proximity to Brabus and AMG V12s would be a no brainer for any RWD Skyline engine death event. In my case, because my car is my daily, anything that I do wrong that means I have to do it again is both an absolute pain in the arse (simply having to do it again), and also a doubling of the pain associated with having the car off the road to work on it. I would class a botched head gasket install as not being "engine death causing". More a case of "f**k it's still leaking!"
    • Yeah, this is more stuff like transmission/clutch R&R. Intake manifold R&R. It's not super complicated, but each step matters and you need to be careful and patient. I have heard stories for example of people not figuring out the super coppermix twin plate orientation and getting it wrong on assembly. Removing a cylinder head and putting it back in once it's machined isn't that hard, following torque sequence to install some cams isn't that hard either, but somehow I've seen a lot go wrong between here and there. Scraping off all gasket material isn't that hard either, but I've seen shops ruin heads by using a roloc disk that was too aggressive.
    • There is some shops in Germany that have quite a bit of experience with JDM performance 4-wheelers. I think if it actually comes down to it I'd let one of them do the head gasket. Killing an RB26 is too expensive a risk just to save some money by doing it yourself.
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
