And the battle continues........
Timed the engine on points,ran a compression test again still did the slow build up starting to think that compression tester is maybe defective or ill need to try another one or try that same one on another engine to confirm... havent start the engine to see if its still doing the low vac issue...
  • Replies 50
Posted Images
5 hours ago, NEO25T said:
Well fire that puppy up, you might have fixed it lol
Is your idle control plugged in properly, if thats not opening to keep the motor running, rpm will be down as well as vacuum
illl start sometime this week.. just need time to finish mount up other components.....am running no IAC/Idle control.....
This is the slow compression build up i was referring to
How did you lap the valves, and why?
Do a leak down test or at least out air into the cylinders, I reckon you have valves not Sealing correctly. That's my current guess anyway
when i pulled down the head while communicating with you guys i did a kerosene leak down to see if any vales were leaking and if there was any only one or two which was slight on the exhaust side. Intake had no sign of leakage and i did all valves with the head turn over and the kerosene settle on the valve based..... so am trying to get another compression tester dont have access to a leak down tool.....
Reason why i lapp the valves well more fine on intake and coarse and fine on the exhaust is cause the last two valves of the exhaust had a slight bend so all 12 valves were lapp over on the exhaust which change the clearance i believe....and after that is when this issue was shown..... I already change the clearance to tomei spec of 0.018 thou on the intake... i may/might start the engine and see if what i did made any difference...Engine time on points am only left to believe either the vct might have a play in this but i doubt
all that was done to the head when taken off was - Replace exhaust #11 and #12, Tomei 1.2 head gasket,stock head bolts torque to nissan specs,changed valve seals ,lapp intake with fine and exhaust with fine and coarse...Thats about it....
Edited by DTT_Eruc
Have you done a wet compression test at all?  I'd like to see a dry then a wet test and see if there is much difference.  I realise that the focus is on the head and valves being the issue [and I tend to agree], but a wet comp test would confirm this.
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
