Ross make a billet bracket that relocates the power steering pump on an RB to where the A/C compressor normally lives. It is designed for track use, and is to shorten the PS drive belt and prevent the belt jumping off.
We have an R33 track car, and have broken or lost the power steering belt several times now. The belt is a 3PK, and only goes over 2 pulleys - the harmonic balancer & the PS pump. Each time we've lost the belt, it has been when downshifting from high revs - when braking for a corner at the end of a straight. I believe the reverse torque when the clutch is released is causing the belt to jump, and sometimes enough to come off.
I'm looking for anyone who has used this Ross bracket, or any other feedback on it. Any assistance would be appreciated.
Edited by GeeDog
I'm going for another solution, electrohydraulic power steering pump from a mr2! More info on this site https://www.google.com/amp/s/www.diyelectriccar.com/forums/showthread.php/power-steering-using-toyota-mr2-ehps-19505.html%3famp=1
Not because I've had issues, but my rebuild/refresh turned into a restomod and this also gives me more space under the bonnet. Hope someone got experience with the bracket
38 minutes ago, iruvyouskyrine said:
Sorry if i'm missing something obvious. Do you run the factory setup and have issues, or you run the ross item and are having issues after the switch?
We run the factory setup and have issues. The Ross bracket is supposed to stop the issues, and I was looking for anyone who has used ne to confirm that I'm not wasting my money - they aren't cheap.
Following with interest, while I agree it's a pretty expensive bit of kit for what they provide but when you consider that you could ruin a race weekend with a damaged belt or bin the car due to power steering failure it doesn't seem so bad.
FWIW I have put Astra electric power steer on a car and would never do it again without being able to adjust line pressure vs wheel speed, it was like driving a 70's Valiant with power steering with zero feel/feedback.
But, in these days of Arduino, surely that's a triviality.
  • 3 weeks later...
Just to clear this up GeeDog, I work for Ross Performance as a machinist and in tech support. That power steering relocation bracket is designed for use when a customer needs to use one of our 1000hp Race Series Harmonic Dampers and also retain AC (without flicking belts off as soon as you hit boost). It is used in conjunction with the rest of this kit to space the PS and AC units forward 25.4mm for their new belt path.
https://rossperformanceparts.com/product/nissan-rb-air-conditioner-relocation-kit/
Perhaps this would help fix your problem?
https://rossperformanceparts.com/product/nissan-rb-power-steering-idler-assembly-to-suit-serpentine-belt/
Troy
Edited by Bowlsclubboy
grammar
  • Like 1
Hi Troy, nice to hear from you.
Ok, that info doesn't seem to be readily available - the page for this kit has no info at all on what it's for, how it works etc. My info on using it to stop the belt coming off came from a third party, and seemed to make sense in the absence of other data.
It looks like it would help, but the webpage says "Note: This assembly is designed to fit with a Ross Nissan RB25 Billet Power Steering Pump Bracket (will not fit on a OEM RB30 power steering pump bracket)." These 2 kits together are $900+ - thats a lot of belts. Maybe I'll stock up on them.
Cheers
Geoff
Use your ECU and use PWM to control the duty cycle vs. vehicle speed.
Similar strategy to controlling fuel pumps where DC is mapped against manifold pressure.
We don't live in a world with Microcraps and PowerFCs anymore :)
The required info for being able to do this isn't readily available. I did a fair bit of google-fu when looking to convert to elec PS but everyone says the same thing 'just PWM the output'. But when pressed for info nobody has ever done it they just assume its that easy but finding any actual info about PWM/CAN controlled powersteering pumps is extremely difficult.
I'm sure there is people out there who have done it but nobody is forthcoming with any easily digestible information.
Thanks Geoff, this is what happens when the webpage designer isn't given the exact information (or none at all) and they decide to think for themselves. The idler will fit OEM power steering pump brackets for RB20, RB25, RB26 (and i thought RB30 but will confirm) as well as any brackets that we've manufactured. As for the PS relocation kit, I'll get some info added to the site to save future confusion. Feel free to PM me or call the shop if you want more info.
Troy
Pretty sure the older style ones have inbuilt controls that have a sort of boot up cycle so pulsing the input to them is actually counter productive. Newer ones with actual CANbus input are available but as said there's no info about their control systems.
As others have said it's not that simple. I didn't bother trying a timer (for pump start up) then SSD voltage control vs wheel speed because that car didn't have an ECU that could easily be made to do that (Autronic SM4).
I would still use a powered column if I was to do it again since they are simpler to configure the amount of assistance provided.
We are running an RB25/30, so RB30 bottom end (including P/S bracket I think), so confirmation would be good.
Thanks again for the info.
21 hours ago, iruvyouskyrine said:
The required info for being able to do this isn't readily available...
I'll share what I have, this applies to MR2 "Spyder" EHPS.
5V digital PWM (on-off) to pin 2 in the middle connector, someone measured frequency VS current draw/pump output.
20 Hz       8.5A
36 Hz       7A
52 Hz       5.6A
63 Hz       5A
83 Hz       4A
110 Hz  ~3A
>150 Hz 2.2 - 2.7A
Information regarding pin numbers and some more good-to-have can be found at https://www.ffcars.com/forums/1812812-post48.html
  • 7 months later...
Hi guys sorry to bump an older thread. I'm wondering does this bracket help with the spacing of the balancer? I have a similar issue on my rb25 when we installed an ATI balancer and still have the stock PS location/bracket so it is slightly off angled due to the balancer being further forward and under higher rpm just throws the belt. is there any difference from the ross and ati balancer?
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
