will installing a gts4 manual RB20det ECU to rwd gearbox and rb20det auto engine loom cause any issues? any known sensors needed different from rwd rb20dets?
currently I have an ecu (likely auto) with an auto engine loom (if they are different from manual looms), but its wired to a rwd rb20det and gearbox and starts perfectly fine. I got a gts4 manual rb20det ecu but it doesn't start the engine, if I get a lucky start I have to hold the gas pedal but once I let go it will not start again at all. Would I have to change the cas timing? tps readjusting? idle air screw readjust?
Edited by nicostar
Post up the number of your original ecu  - someone may be able to tell you if its an auto one.
In any case I would use the one that works. You may be able to get it Nistuned later if you start modding.
Shouldn't have to change anything. They are the same thing. Auto ECU will happily run a manual. GTS4 ECU is same same as RWD. If the GTS4 ECU is not running your engine, it would suggest that there is either something wrong with it, or perhaps it is already Nistuned or otherwise reprogrammed for different sized injectors/AFM or something.
  • Thanks 1
i don't have the number for the ECU I am currently using, got it like that. I don't mind if that one is auto or manual it is working fine, the second ecu I got is gts4 but as my backup ecu, it is not working.
thanks GTSBoy, I really just wanted to have a backup ecu. I bought this gts4 manual one from ebay, turns out it is no good. I see no signs of nistune in it at all. It can be nistuned but I'm not ready for that yet, I just want to ensure I have a backup ecu, and if I do get the nistune chip the ecu should at least be working, in this case it isn't.
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
