Just wanting a shout out of nsw cefiro owners since i might organize a cruise/workshop day or something seeing as we have a few in here. Good to get ideas and stuff going on forums even better when u see same cars in the flesh and can get help/advice. Ive only ever seen 2 others in nsw since the last 2 years and thats damn rare.
Since i have worked on the car myself mechanically and others since ive had it would like to help out others if need be. Yes people share the lurve.. :cheers:
ceffo.
https://www.sau.com.au/forums/topic/47843-cefiro-nsw-owners/
Hey guys im going to this on 4th (sat) September. Should be good. Reply or Pm if u wanna hook up and have a look. No use having a drift car if u aint gonna drift.
R31 House & East Bear to attend the Sydney Drift Nationals
_____
Mr Shibata from R31 House and Mr Iwamoto from East Bear will be in Australia for Round 2 of the HPI Drift Nationals at Oran Park Driftland on September 3rd and 4th.
Some of you may already be aware of his visit from the diary he keeps on his website (www.r31house.co.jp ).
They are also working absolutely flat out to have an R31 House drift car ready and in Australia for the event.
Mr Shibata would like to thank all his fans for the emails that he has recieved so far however simply doesn't have the time to keep up with them all. If anyone would like to send an email to him or pass on a message please send all your emails to Powerplay Imports.
Powerplay Imports will also be hosting a promotional day at the shop on Sunday September 5th to give all of you an opportunity to meet Mr Shibata and Mr Iwamoto.
https://www.sau.com.au/forums/topic/47843-cefiro-nsw-owners/#findComment-976482
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
