r34 engine rebuild
Is closed loop ....o2 feed and active changes?
And open loop means the loop is broken and or uses maps. Loaded maps being wot and high throttle maps tuned in the ecu like an idle map but for when the cars power is under load?
Google closed loop and open loop control systems.
Get on YouTube if you still can't work out what an open/closed loop control system is.
It is very clear you do not understand what each term means.
Regarding your 'load map', there are high load areas on the fuel and timing maps, I've never seen a separate map specifically for when the engine is on high load. I hope such a thing doesn't exist because it would be a pain to tune, constantly swapping between multiple maps.
While your googling, Google fuel map and have a look on the images, you'll see the maps cover the entire rpm and load range the engine operates in.
I was serious about the English as a second language question, do you speak another language?
  • Like 1
The gauge is a gauge not sensor.
The part of the maps i refer to you know of. As it is part of the mapping. Not its own map . Dont be foolish about it.
I will google open and closed loop fueling.
"Defining Open Loop and Closed Loop o2
Open loop is when the ECU is not referring to the o2 sensor for feedback. ... Closed loop is when the ECU does refer to the o2 sensor for feedback. Using the o2 sensor the ECU will modify its fuel table based on the readings the o2 sensor is seeing."
I may have invented load maps but ment load area of the map. Eg....
"Pulling a fifth-wheel camper up the Rocky Mountains at highway speed, for example, puts the engine under a huge load and requires a lot of energy. The ECU gets input from all of the sensors on vehicle speed, air intake, pressure, and temperature and plots a specific point on the imaginary graph. The computer is programmed to tell the fuel injectors what to do at that very point on the fuel map, and it sends out the appropriate message -- without any more input from the driver."
open loop and closed loop is well known i believe and maybe you should do some googling and maybe you will see where my terminology isnt correct. But its the jist.
That's not actually true. Was clearly written by someone with half an understanding. What really happens is that the ECU leaves the values in the fuel table alone and DOES NOT modify them. It may or may not use them as the base for the calculated fuel qty that it will then apply the feedback factor from the O2 reading, and also apply the long and short term fuel trims if and as they exist.
And how do I know? Well, the Functional Description documents that I have been writing recently for Burner Management Systems for a couple of different rotary kiln systems with fuel-air ratio control WORK IN EXACTLY THE SAME WAY. I even have a CO sensor in the kiln exhaust as a Safety Function.
The capitalised names above are capitalised for a reason. A Safety Function is such a serious thing that we use capitals when writing about it. A Functional Description is what is used by the system integrator and programmer to write the PLC code. All of this is covered by AS 3814 and AS/IEC 61511.
The words that are in all caps are just me shouting.
Is that not what it is saying in laymans terms, "as it MODIFIES" does not represent any one actual change, and is interpreted to myself as basic word usage so that it can be used to cover all different aspects and types of change and ecu's.
It doesn't modify shit, it applies a compensation/trim in either short term and/or long term trim.
The fuel table stays as is. However in aftermarket ECUs it stores the trims and you're able to apply it to the base table. This is the only time it "modifies" the fuel table.
  • Like 1
  • Haha 1
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
