Hi everyone,
Last Sunday on the Nürburgring I noticed my PCV hose was not doing that well :
https://youtu.be/clfarpgriyA
It was really soft, completely folded due to depression inside, I had to turn it a bit to improve the flow inside but it did not help a lot.
I don't believe this hose is stock when I look at the shape it has (looks like a basic hose coming from your local auto store) and was planning to replace it with a kind of reinforced Silicone one.
After speaking about that with friends I got advised not to use silicone as apparently the airflow charged with oil vapors could damage and rot the silicone hose from the inside. Some of them advise me to use rubber fuel lines, some others told me about steel braided lines (but honestly, I don't wanna start messing around with fittings and so on).
-> if anyone had to replace that one, what kind of hose did you use ? Obviously it must be soft enough to be routed from the cam cover to the intake plenum, but strong enough to keep its shape and carry the airflow inside...
Thanks in advance for your help, and please forgive me if that's a silly question.
Wishing you all a nice day
https://www.sau.com.au/forums/topic/478472-pcv-hose-failure-on-a-built-rb25det/
Go to a hydraulic hose place (yes they exist) and ask them for a piece of hose the right diameter that is temperature and fuel resistant. Doesn't need to be steel braided - tell them the application and they will find you something suitable. It will be expensive and you may have to pay for a metre minimum.
  • Like 1
Thanks mate. I went to a shop that's specialized in automotive material, parts and tools. They gave me exactly what you said, temperature resistant fuel line and I got a full meter.
37 minutes ago, GTSBoy said:
There's a lot of vacuum in that hose. You should investigate what is blocking the inlet end of it.
I'm not sure there's really something blocking mate. When I press on it like in the video, I can feel the flow inside. I bought a new hose and when I compare it with the worn one, it appears to be way more rigid - I don't know where the old one comes from, but I'm sure it was just too soft to handle the vacuum... let's see how it'll be with the replacement one.
Thanks for your answers !
When mine failed, i used aluminimum tube and a bending tool to make the stock s-shape, although obviously you could bend it to pretty much however you need. Then just use short joiners of oil resistant hose to connect to the manifold and pvc end. Will last pretty much forever, and was cheap.
Great way to solve the issue mate, will keep that in mind should the new hose fail ?
Thanks !
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
