Great clip, would you do the event again? What do you reckon it set you guys back in the end?
Laughed at the Integra pulling away after the chicane then at his shit line into T1.
Car really di dnot want to turn in did it, you did a great job keeping the momentum up.
Yea would do it again in a heart beat
costs who knows 2-3k per driver
but that’s a week away from the kids on the piss with the boys and 3 days of racing
so cheap holiday I guess
there are some pretty special drivers there so you have to be on point when overtaking as some of the cars are quite fast and make you work for it
I think I'm going to try doing a use oil test for the new motor, I want to get a real idea of what kind of life the oil really has in it (as i wanna use some half decent shit).
Maybe no need to worry about that for the dirty30.
How do the rules work with lemons? Engine swap count to your budget?
I just can't fathom how any builds a car for the budget or is it only the original purchase price of the car must be 1k or less? I know safety gear is "free".
No idea how the rules work
having been to a few it appears you get a shit car and stuff a decent motor in it
eg Bmw318 with 330 motor ( blew past us like standing still)
every pulsar there had a neovvti upgrade engine
if you go there to win your missing the point
its more about getting on the cans and having a good time
I dont care about winning, but I do care about not spending the entire weekend just working on a shit box and not driving it.
Was that BMW the polizei one? That was a local car from a mate of mine.
Yea we though the same
most reliable engine Nissan make ( stilll shit two cas)
and dodgy home welded diff means we ate a diff
We have done the event 3 times now and only ran trouble free once
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
