Just now, ActionDan said:
See, diesels are shit ;)
Ha ha.  Having started my apprencticeship doing valve clearances on Holden Rodeo's I do tend to agree on old (ie Toyota) technology engines.  I forget all my hate when you see what a modern one can do.  We've delivered 3 Audi SQ7's this year with the 320kW 900Nm diesel V8 in them.  Now THAT is a diesel engine it's hard to hate on!  Sounds good, goes good and surprisingly good fuel efficiency if you realise the throttle isn't an on/off switch.....
  • Like 1
Mine is only a GXL so it's just airflow in there, will be AC if you have it on, but it's not an actual fridge like Kak/VX.
What year model did you have, wanna know if it was the same as my current one so I know how shit it's gonna be towing 2T lol
I'd be tempted to drive it... just to check it out you know ;)
I've looked at Q7s lots of time for some reason.
I've got an SQ7 on a boat docking in a few weeks.  Not far from Albury to Shepparton.....
Ahh, yeah 120s were down 20-30kw's on the 1GR used in mine, plus mine is tuned/intake to help a bit.
Still slow, just not "as" slow.
The 3L piston breaker is f**king anemic and couldn't pull the skin off rice custard.
A v12 would be sexual.
I do get down to Shep a bit for work, are you down that way?
Well well, V6 Amarok...
Proper overpriced european shitbox with stupid parts and service pricing. The upside is you can look like a king at the job site along with you "Unit" sticker across the back window.
I towed with a new Dmax to an undisclosed location recently with a car on the back and 1200kg trailer, did it well even with boxes on the back.
A Camry will tow 1200kg lol
New Dmax at least looks better than the old one, nfi about how good it is.
A mate has a DMAX for work and an MUX for home and loves them both. I tried MUX, good value, but drives like a ute.
1200 + 1600kg car..
Dmax is basic but I would own one over a Ranger......
2 minutes ago, ActionDan said:
I was just thinking that...
Didn't you start the tow thread originally?
Why is your convertible barbie car going to be on the Haltech series and what ep.
Like, share and subscribe to find out.... :D
  • Thanks 1
  • Haha 2
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
