Hello everyone.
I purchased a highly modified '98 r34 gtt this past February and have run into something completely unfamiliar... Wiring harnesses.
Purchased a new gtx3071r and after a few e-tuning pulls my knock stopped registering completely. Upon inspection one of my knock sensor connectors was cracked and fully disconnected.
I purchased a new knock sensor sub harness and am going to be tackling it this weekend and need a bit of guidance;
1) I have a intake plenum so accessibility to the knock sensors/wiring is nearly impossible, is it easier to go from the top and start removing the entire plenum or go from underneath?
2) Whereabouts should I expect amongst my main harness to find the connection for the knock sub harness? Would help if I knew a ballpark even mid engine'ish.
Any info whatsoever would be greatly appreciated. I've done lots of research and there seems to be very minimal info around the knock sensors & their harnesses for the rb25. I had a modified evo prior but unfortunately wiring & skylines are an entirely new world to me.
Thank you so much and have an amazing day!
- @ThePurpR34
Edited by Thepurpr34
https://www.sau.com.au/forums/topic/478477-knock-sensor-harness-locationaccess/
if it's anything like the r33 gtst - which it probably is - go in from the bottom, remove starter motor, and you will have plenty of room to get the rear plug. I only replaced the plugs, didn't pull apart the harness, but I believe the KNK sensors and fast idle are on their own loom, just taped together with the gearbox/alternator loom, so you either need to remove it as a whole, or try cut it apart with on car - removed the whole thing, and will almost certainly be easier for you.
The joined harness assembly will possibly be connected to the 3x gearbox connections, the alternator, the enginebay fusebox x2 points, the fast-idle, and knock sensors.....or possibly it will have other points too, can't remember, but that's the starting point.
When refitting the starter, ditch the top bolt and put a stud/nut in there instead - alot easier to get the starter on/off in future.
  • Like 1
  • Thanks 1
  • 4 years later...
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
