Djw085 Posted August 31, 2019 Share Posted August 31, 2019 I have an r32 skyline wa auto but converted to manual, just installed a fully rebuilt motor and can’t get it running right, #3 cylinder is not firing but I’ve tested the injector is pulsing when running, changed injector just in case, swapped the coils which made not difference so that ruled out coils because the miss remained in #3 cylinder, replaced the plugs to brand new ones, checked the wiring harness which had power, checked earths and injector leads, any ideas on what it could be? Link to comment https://www.sau.com.au/forums/topic/478512-rb20det-missing-on-3cyl/ Share on other sites More sharing options...
KiwiRS4T Posted August 31, 2019 Share Posted August 31, 2019 37 minutes ago, Djw085 said: I have an r32 skyline wa auto but converted to manual, just installed a fully rebuilt motor and can’t get it running right, #3 cylinder is not firing but I’ve tested the injector is pulsing when running, changed injector just in case, swapped the coils which made not difference so that ruled out coils because the miss remained in #3 cylinder, replaced the plugs to brand new ones, checked the wiring harness which had power, checked earths and injector leads, any ideas on what it could be? Who built the engine? If it wasn't you maybe one cylinder has broken rings. Try a compression test to reassure yourself. Link to comment https://www.sau.com.au/forums/topic/478512-rb20det-missing-on-3cyl/#findComment-7914815 Share on other sites More sharing options...
Djw085 Posted August 31, 2019 Author Share Posted August 31, 2019 Nizzpro rebuilt it, I've had it down there since installing it and he told me it was the tps, but I've replaced and set the tps and it's still misfiring, done a compression test and it all checks out fine. Link to comment https://www.sau.com.au/forums/topic/478512-rb20det-missing-on-3cyl/#findComment-7914830 Share on other sites More sharing options...
blind_elk Posted September 1, 2019 Share Posted September 1, 2019 When you say "swapped the coils", do you mean "new set", or swapped #3 coil with a coil from another cylinder? The injector is "squirting"? Only thing left is the igniter. Or a broken wire on #3 coil loom. Link to comment https://www.sau.com.au/forums/topic/478512-rb20det-missing-on-3cyl/#findComment-7914871 Share on other sites More sharing options...
Djw085 Posted September 1, 2019 Author Share Posted September 1, 2019 Swapped over with another coil which resulted in the same cylinder not working. I had a spare igniter there too and swapped that over as well only to find the same problem, I also pulled the insulation off the coil wiring harness to see if the wire was broken but nothing. #3 spark plug is the only one clean as if it’s not biting fuel. I’ve also taken the coil out and tested the spark plug for spark and it has spark so I’m guessing it’s fuel but I’ve changed injectors with no luck either Link to comment https://www.sau.com.au/forums/topic/478512-rb20det-missing-on-3cyl/#findComment-7914872 Share on other sites More sharing options...
blind_elk Posted September 1, 2019 Share Posted September 1, 2019 #3 sparker should be covered in fuel if the injector is working. If the coil is working, then you have a wiring problem with #3 injector. Link to comment https://www.sau.com.au/forums/topic/478512-rb20det-missing-on-3cyl/#findComment-7914876 Share on other sites More sharing options...
White GTS-T Posted September 1, 2019 Share Posted September 1, 2019 Rag left in the inlet manifold choking cylinder #3 is my bet Link to comment https://www.sau.com.au/forums/topic/478512-rb20det-missing-on-3cyl/#findComment-7914885 Share on other sites More sharing options...
Djw085 Posted September 3, 2019 Author Share Posted September 3, 2019 No luck as yet, going to compression test all cylinders on the weekend, the mechanic seems to think it’s a washed cylinder from a leaking injector I may have had, the motor has only run maybe 30mins since being rebuilt so don’t know if it’s possible that can happen after only 30 minutes of running? Anyone heard of this? Link to comment https://www.sau.com.au/forums/topic/478512-rb20det-missing-on-3cyl/#findComment-7915094 Share on other sites More sharing options...
