I've been reading up on what I need for an oil cooler. I'll be using 10-AN fittings but I'm getting clashing info on the cooler core size that's required. The two kits I'm looking at are the Hel/Setrab and Mocal, both will include a thermostatic plate.
Oil Cooler - Nissan - R32 R33 R34 Skyline / S13 S14 S15 Silvia / Pulsar GTIR / 350Z 370Z - Oil Coolers & Kits - Cooling - Engine & Exhaust | JDM Garage UK - Nissan Specialists
Hel offer 13,16,19 and 25 row coolers but don't give any recommendations for size for the application
https://www.ebay.co.uk/itm/SKYLINE-GTR-GTS-T-AN-10-JIC-S-STEEL-BRAIDED-HOSE-OIL-COOLER-KIT-ZQMBFK-3-4UNF/401441858211?fits=Car+Make%3ANissan%7CModel%3ASkyline&hash=item5d77cca2a3:g:dKQAAOSweExaCtAD
Mocal's listing includes a 10 row. As a rough guide they recommend a 13 row for applications upto 200hp. I'm currently circa 300hp but will be around 400hp by the time I'm finished.
I'll be mounting the cooler in the driver side wheel arch infront of the windscreen washer bottle. I'll be fabricating a duct for the Altia bumper to help with slightly better air flow.
Would it be the case of measuring up what room I have and order accordingly?
https://www.sau.com.au/forums/topic/478521-r34-gtt-oil-cooler-info/
Get a 19 Row, 25 becomes a pain in the arse fitting but if you're making decent power and hit the track then 25 is probably more optimal.
I used to run a 19 row Mocal (genuine core not dim sum special) with 370kW+ at Wakefield and after 6 to 8 laps on a 30 degree day oil temps would hit about 110 to 120 degrees.
Conversely, I ran/run a 25row, and yeah the fitting is POSSIBLE (on either side of the car) but it gets into the area of wondering how many of those extra rows are actually getting airflow.
However at the track I would pull an indicator out and see oil temps a little cooler than above, about ~105C, down from 150C without the cooler at the same track in the same conditions.
There will be expletives fitting it though, but it can be done.
Possible with a 25 row, but it does sit low. If I were to come off the track into the sand/gravel trap there's a chance it might hit the ground.
Between the core and the bottom bumper, there's about 2cm of space.
20171218_201928_HDR.thumb.jpg.964b24dda8afe5d5332faa5b08c5a4c8.jpg20171218_201920_HDR.thumb.jpg.6edb847ea018f28eb91a7ff59030f099.jpg
  • Like 1
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
