Hey guys!
I just bought a manual r34 gtt and i’m absolutely loving it.. but i’ve got some questions
1. The car is fairly stock apart from a HKS intercooler that looks like it’s at the end of its life (the condition isn’t the best, i’ll provide photos)
Would you recommend just buying a whole new kit or just get its refurbished? if so what kit would you recommend
2. After getting the car all checked over.. what modifications should i install first? A list of 1DA9FA28-06F3-4B79-A164-013C1039609D.jpgthese would be greatly appreciated
Can’t think of anymore questions but i’m sure something will pop up and i’ll just ask again!
thank you for your time and help
https://www.sau.com.au/forums/topic/478535-questions-about-my-r34-gtt/
Tidy looking car.
May well be nothing wrong with the intercooler - just clean up the front and if you are worried, pressure test it.
Incremental mods tend to be a waste of time.
If you want it to go faster look in the RB25 turbo upgrade thread and see how much power you want.
Then open a special bank account and save up the $5k or $8k or whatever depending on what you have decided and do it in one hit.
  • Like 1
10 hours ago, KiwiRS4T said:
Tidy looking car.
This... good advice!
Do it once... do it right!
Thanks! ill check it out..
Would you recommend any way of 'cleaning' the intercooler?
The intercooler piping looks sheeeit and i was just thinking of sanding it down and hitting it with some primer and spray paint maybe..
thanks for your advice, im sure ill have some more questions soon xD
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
    • Ok now I’m extremely jealous
