Looking for a diagram of the transmission wiring loom or even a few pictures of the under side of your cars would be great !
Seems somethings flew up and hit the underside of the car causing part of the wiring loom wrap around one of the shafts and cause havoc.
Wires are green, green/yellow, green /white, yellow/blue, yellow/white and black with silver spots.
It had blew a fuse as well and wasn’t giving any 4wd lights. Sorted that, now getting 20 flashes from the ecu meaning harness is faulty
I was going to just rewire it’s as I don’t fancy 200+ on a new one and the effort of pulling it all out and looks like I’d have to take the intake off too.
Im fairly sure the ones circled are the ones I'm missing.
So yea if anyone’s a diagram or any photos be much appreciated cheers !
It also took these out obviously not oem and not sure of orientation but I’m sure I’ll find out.  Going to the steering rack D18F1212-12D7-406A-8285-D7CCAF291882.thumb.jpeg.5fffd1e0bb9836768f206e91b274330e.jpeg
Edited by McGarryR32
https://www.sau.com.au/forums/topic/478536-32-gtr-transmission-harness-diagram/
The 2 you circled with covers are the gearbox reverse and neutral switches. It's possible they are 12v/+ switched (they definitely are in stagea, I remember having to fix one) so you've probably blown at least 1 fuse as well. As per the pic they are a long piece of loom that run straight past the front drive shaft so very likely they are the culprit. Neutral switch doesn't matter on a GTR (it is a signal to the ECU, but I have no idea why) but reverse obviously means you have no reverse lights.
I have an original/printed manual so remind me before the weekend and I can dig out the colour for each part
The other one you circled with the rubber boot is the oil pressure sender. Been too long since I looked at a standard dash but I'm pretty sure it has an oil pressure gauge so you will be able to tell when you start the car if that is connected and working.
Oh and power steering rack wiring is for the speed sensitive steering that most people hate. I imagine you haven't noticed a difference....no idea if it is safe to connect them wrong way around, but since they are same colour in the original loom and same connectors....just plug in and see if sparks fly and fuse blows, or if your power steering works...
Well, 20 attessa flashes is covered on page CH-74, and "faulty harness" is one of the potential causes. But when you look at the terminals involved in that error they are between the attessa relay, attessa ECU and attessa pumps. None of them are in the harness you showed.
On CH-66 however, it shows reverse light being an input to the attessa ECU (perhaps it disengages in reverse?) so that short may be your issue. It is powered by fuse #21 and goes via the switch to pin 32 of the attessa ECU
I'd start with cutting the ends of those wires flush so they are not shorting to earth to see if that clears the error
  • Like 1
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
