Re oil control - you won't be able to do much at all without pulling the engine out, and if you pull the engine out it's probably worth doing as much as possible. This includes an extended & baffled sump, and a drain from the back of the head (you need to drill & tap holes to mount this, which is why it can't be done with the engine in the car). Then you need to decide if you want to remove the head, and fit restrictors & drill out the block oil returns. It can get expensive very quickly, but so can oil starvation.
Lewis Racing Engines in SA sell extended baffled sumps & head drain kits at reasonable prices. If you do buy a sump, get some extra nipples added for a catch can to drain to, and for the side head drain if you ever change to an RB30 block.
I tried just adding more oil, but found that it just got pumped out the breathers really quickly at high revs.
I believe the RB25 needs these mods as much as a 26 does. I destroyed an almost new turbo from what was almost certainly oil starvation, and the broken bits of turbine scratched the bores of a freshly machined block & new forged pistons. Should have done it properly the first time.
Re harness mounts - I made a harness bar that bolts to the top mounting points for the rear seatbelts. Basically a length of roll-cage bar, with a bit of 50x5 flat bar welded to each end. This puts the harness angles pretty much horizontal, and it has been scrutineered probably 30+ times with no issues.
  • Like 1
Just in case anyone else buys a Cusco Safety 21 4 point full capacity Rollcage (281 270 A20) to get the harness bar in i have bought two of the FIA Roll Cage Joints and will weld them to the cage with a piece of 40mm tubing. the joints are available here https://www.rhdjapan.com/cusco-40mm-fia-roll-cage-joint-kit.html
This allows the harness bar to be removed when not needed
The add on bars cusco sell directly do not have the strength to be used for a harness.
Edited by Tobz
Cage arrived today!!!
I got the Cusco 4 Point Full Capacity Cage which follows the roof line for the main hoop and goes over the top of the windows for the rear supports. I've ordered an FIA 40mm Roll Cage Join to add a harness bar across the two rear struts.
Here is some pictures
4 hours ago, WR33KD said:
Is the bolt in cage FIA approved?
Nope, all the events ill be entering dont require a cage for a street registered car, but for my own safety i wanted to run a harness and a hans device (Just feel safer). Also im not 100% sure i trust the A pillars on these cars, they look tiny!  So for this purpose the cage is perfect.
10 hours ago, Manuel Kasko said:
Loving that you're keeping the build updated
Was hoping you wouldn't mind, is nice to see the full history of a car in one place :)
Arghhh, I keep buying parts for the car but don't have the time to install as yet and still waiting for my new shed to arrive.
But ordered the alpha omega racing Evo brake upgrade kit today!
Took the car to Wakefield on the weekend, and it did not inspire confidence under brakes
Need Elig or Intima pads? ?
I can help with either and also DBA rotors and Turbosmart stuff.
Most of the time the brakes aren't too bad, but it's the choice of friction material that is the real let down.
What times were you lapping at Wakefield?
Yer i was running Project Mu HC800 pads but they just were overheating after a few big stops. Was running fresh Motul 600 fluid too.
Times on the weekend were terrible though as we had an oil spill on turn one, so couldn't really attack the braking zone there too hard.
Yeah HC800 are the Thailand version of the HC+
You'll find some Aussie retailers will tell you that the HC+ and HC800 are the same, they're very different.
HC+ is made in Japan (and the price shows too)
Do you need new pads for your new setup?
  • 3 months later...
Finally started working on the car again! Been slow going as I loved house and had a heap of issues getting my shed setup! But it’s all working now.
just installed my whiteline swaybars front and rear (27mm front and 24mm rear) hoping this will fix some of the rollyness in the car :)
also got the alpha omega brake upgrade kit, in the process of painting them up before installation. Added some pictures of them sanded back and one caliper I have finished painting. Hoping to have it all completed next week! Hopefully! Next few weekends will be busy as we are also building a n15 sss pulsar for lemons as a replacement for our current Celica we have been running.
Also installed some led rear tail lights, just need to find away to restore the fronts, has a bit of oxidation on them.
Edited by Tobz
Got a bit more work done tonight, was raining here in Canberra so couldn’t finish the brakes off as they still need some paint. So started work on the oil cooler. The blitz oil cooler kit is really good quality and basically is bolt on so far (had to shave a bracket slightly due to the oil cooler bracket). Otherwise so far so good, just need to tighten it all up and install the sandwich plate after.
Only thing I don’t love is that the oil cooler lines run under the radiator (see last pic above). However it seems to be higher than the tow hook and cross members etc so should be fairly well protected... unless I need to use the tow hook.... might need to install another tow hook somewhere
also the lines are beautiful braided lines, but they supply some good quality plastic hose protectors, which I am using :)
Edited by Tobz
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
