This turned out better than anticipated! My reupholstered steering wheel came back. Guy did an amazing job. Was done by Guru Leather in Adelaide. You ship the wheel to him with a return postage bag. Let him know what you want, and he returns in better than new condition!
i asked for Alcantara and leather, he recommended suede as it’s cheaper and wears a bit better. I also asked for res stitching. Was $350 for my leather suede options. I’m assuming prices vary depending on multi factors.
anyway super happy with the results!!
  • Like 1
Yer I wanted to keep the car as legal as possible. I looked into the mines wheel, just jap have an option and the random guy on the Facebook pages. But this was quite cheap in comparison and exactly what I wanted. Highly recommend the guy!
On 10/04/2020 at 11:07 AM, Milkmun said:
Cube shifter, please do a little review when you drive it
Hey!
so finally took the car for a drive today. I think the best way to describe the change is the shifter now feels much more direct and mechanical, kind of similar in feeling to pulling the bolt back on a rifle. Just feels super direct and satisfying.
there is some additional noise in the cabin, but nothing that bad, it’s more than acceptable. 100% recommend this. It’s so much shorter, nicer and direct.
12 hours ago, Kinkstaah said:
why get suede on the parts you don't touch?
I do a lot of sim racing and I’ve realised I actually hate holding onto suede without gloves and when I am wearing gloves it doesn’t matter if it’s leather or suede for me. Also I absolutely hate the maintenance, you have the clean the damn thing every month and eventually it wears so bad it looks like leather... and I didn’t want a full leather wheel, I wanted some variation so went with the above :)
  • Like 4
Had a bit of fun on the weekend! Finally got around to installing the Cusco roll cage I’ve had since September!
super simple to do, took about an hour. I’m waiting now for some 40mm roll cage steel to arrive so I can get a harness bar added on.
Just a reminder this cage is not adr or cams approved but for the track days I do in the skyline don’t require one. Just wanted to add this in so I can run a HANS device safely.
did need to move the wiring harness a little, but it literally just pulls off the floor and you can move it around the cage.
cage I got is designed to keep your full stock interior, so far only needed to slightly cut the carpet, but clears all the panels fine. Still need to test fit the rear seat
  • Like 1
  • 4 weeks later...
Well Wakefield finally reopened and I managed to get to a track day there on the 20th! Was good to be out and about and able to give the car a good run.
quickly ordered some 265/35 18 V70A semi slick tyres and mounted them to the Kyoto rims. And managed to test all the changes to the car. I was not going for outright speed as the car had so much changed so I wanted to get an understanding of what the car was like.
overall was really really good. The handling was neutral, I didn’t get any understeer and just a tad of oversteer in slow corners if I wasn’t smooth on the throttle. Overall I’m super happy and confident in the car now.
i did have one issue which stopped me really getting good times. I haven’t upgraded my brake master cylinder to the GTR version yet and that meant the brakes had almost no pedal feel and was very very easy to lock. Also they seemed to overheat after 5 laps, so looking to upgrade to a two piece rotor and Forodo DS3000 pads.
Ended up with a 1:11.2 which is not a hugely quick time but good enough considering it was a shake down day!
also it seemed the track wasn’t overly fast as most people seemed 1-2 seconds off their normal pace (May also be lack of practice in the last few months!!)
  • Like 1
35 minutes ago, PranK said:
Track surface is probably lacking some substance if it hasnt been used in a while. I didn't realise that they were back open, I'm itching to get my 330 out and around it.
It’s so good to be out again. Trackschool open pit days are selling out in less than 48 hours :P
I think we were the first people on there since March!
Edited by Tobz
  • 1 month later...
Only a minor update. At the track day I was overheating the pads and getting bad jutter after 3-4 laps and needed to back off and let them cool down. Have ordered some new brake parts to see if they will solve the issue
got the Attkd 350mm Evo X 2 piece rotors, Ferodo DSUno pads for race days and DS2500 for the street. I decided on the DSUno/2500 combo as they have the same materials so can swap pads without the need to rebed the brakes. As people say, track pads for the track and street pads for the street!
will still run the Intima type d pads on the rear.
1 hour ago, Unzipped Composites said:
Interested to know what you make of the Attkd rotors. I was going to get the same for my car, but ended up cheaping out (which feels embarrassing given how cheap the Attkd rotors are ?)
I’ll let you know :)
  • 4 weeks later...
Small update! Going to Luddenham this weekend to give the skyline a good run. Haven’t been there before, so should be fun!
in preparation I have swapped pads. Now will be using Ferrodo DSUno for track days and then swapping to DS2500 for the road. Went with this combo as they use the same brake compound so don’t need to re bed the brakes every time I swap.
also I have finally settled on my wheel choices for the car.
for track days I run the Koyo SF05 18x9 +30 in satin gunmetal with 265/35 semi slicks (currently Kumho V70a Mediums)
for the road I just got these beauties for the car. They are Koya SF01 18x9 +28 for the front and +32 on the rear in US Burnt Bronze.
Am in love with the colour of these wheels as they change from black to charcoal to brown to bronze depending on the light.
i also needed to change my brake master cylinder to the BM57, but ran out of time :(
  • Like 1
Got out to Luddenham Raceway today! What a great little course, awesome flow and just fun and technical.
had a small issue where the whole bonnet and the car (through the air vents) filled with thick smoke, originally thought it was my catch can hoses melting on the manifold. But after putting some heat tape on that, it was still smoking.
it always happened after around 4 quick laps, decided to call it a day. Did a bit of reading and I’m pretty sure it is just the power steering fluid leaking onto the manifold. Makes sense as I can’t find any oil leaks, it isn’t an issue driving around normally and has only happened at luddenham which is very tight. So hopefully should be a simple fix....
Edited by Tobz
  • Like 3
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
