R32 GTR Pre-purchase inspection - Brisbane
But they won't look for things such as Attessa not working, or if someone has removed the entire HICAS system out of the car and replaced it with a lock bar because they have NFI or if someone has dropped a Nistune into the car and dialled it in or if the turbos have been swapped out for bigger ones, etc.
They're trained to inspect stock ADM cars.
If I were to get an inspection (not that I would need one or pay anyone for it) it would be someone that specialises in JDM shit boxes.
Lmao you people have no idea.
at least I have given him a place to start with all you 2 have done is complain how RACQ are  supposably not qualified for the job ?‍♂️ Then again The internet  is full of  YouTube   Qualified  mechanics as noted above
at least I have given him a place to start with all you 2 have done is complain how RACQ are  supposably not qualified for the job ?‍♂️ Then again The internet  is full of  YouTube   Qualified  mechanics as noted above, oh and neither of you are from Qld according to your accounts ?
Hello Steve.
The few cars I've bought interstate I have always had them sent to reputable and widely known GTR workshops for their PPI.
I've had one each in WA, NSW and Vic. No garage worth their salt would turn you down and a buyer who won't reasonably let it be inspected is probably hiding something.
My advice would be to find out who is the leading couple of Japanese/GTR workshop/tuners and make some calls.
People who look at these cars day in day out can spot a dud a mile away. What i will add though, is any PPI is better than none.
Best of luck! [emoji16]
  • Like 1
Thanks guys for the recommendations! I've thought about RACQ (or similar) but would prefer someone who specialises in the cars
Anyone know of any reputable tuners up there?
cheers
  • Like 1
Have a look through these threads. Some are ancient though, so make sure you follow up by viewing their Google or Facebook reviews or asking someone who uses one of them.
https://www.sau.com.au/forums/index.php?/topic/455728-Which-Workshop/tuner?
https://www.sau.com.au/forums/index.php?/topic/437803-Reputable-Workshop-In-Brisbane
https://www.sau.com.au/forums/index.php?/topic/421478-Brisbane-Workshop/tuners?
https://www.sau.com.au/forums/index.php?/topic/477015-Mechanics-Brisbane-Area
I'm sorry i can't be more help. As mentioned I've never purchased from QLD. [emoji848] Good luck. [emoji106]
cheers man! Missed this post, i'll have a look into places listed here
  • Like 1
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
