Car - factory turbo auto series 2 r33
I am having some issues with boost after going full throttle. What seems to be happening is after doing 1 or 2 pulls typically in 3rd gear it will basically stop boosting the boost gauge will go up to maybe 3 or 4 so psi (running stock boost) and have the same constant exhaust note (loud drone) regardless of what gear it is in. To fix this i usually pull over turn the car off and wait 5 seconds then it returns to normal no constant exhaust note and boosts how it should.
I think it might be worth noting the transmission Is pretty stuffed its the factory Auto gearbox and after warming up it will slip from 4th to 3rd with overdrive on and what sounds like 3rd slipping occasionally after heating up. I have changed the trans fluid and filter that seemed to prolong how long the gearbox took to slip.
Any advice would be greatly appreciated i plan on manual swapping this car when i have the funds for a big box so if the trans is the issue it would be a relief.
https://www.sau.com.au/forums/topic/478594-new-25det-owner-boost-problems/
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
    • Nah mate, safe as $800k apartments
