Hey Guys
I own a 1997 R33 GTST S2. Recently had a opportunity to fill up the tank and reset the km's
Tank is now empty and Ive done 300km! That is terrible economy. I know its a skyline and i didnt buy it for its thriftiness of fuel but 300km?
Ive heard people doing 450-500 on a tank , this seems to thirsty for me
- Done the 100k service
- Replaced fuel filter
- Replaced o2 sensor
- Havnt been flogging it
What else could cause my economy to be this bad even after I have done the above?
https://www.sau.com.au/forums/topic/478598-fuel-problems/
How have you established the tank is empty? You could have heaps left.
What you now need to do is fill up and figure out the actual consumption, not some random guess based on a 20yr old fuel gauge..
  • Like 1
https://www.sau.com.au/forums/topic/478598-fuel-problems/#findComment-7915334
I get pissed off when mine is worse that 13, driving in heavy stop start traffic. R32 with Neo25DET. It has been running 11s lately.
Heavy fuel consumption is very easy to achieve. Launch it, rev it, drive it around in 3rd when you should be in 5th. Pump the throttle up and down so that you never maintain a steady speed (like 95% of the morons on the road). All these things will make a Skyline suck the juice.
Then there's the mechanical issues listed above.
https://www.sau.com.au/forums/topic/478598-fuel-problems/#findComment-7915363
13 hours ago, Jarvojj said:
I did run it dead empty because I ran out of fuel half away down the road, I rolled it down the hill into the petrol station.
Hang on when did you put in 50L? Had it run out of petrol then too? I am sure your tank should hold more than 50L
Unless you are planning to run it empty again you should fill your tank to the brim and at some point before you run out fill it again and then calculate your L/100km...you may be doing worse than 16.6 L/100
Jack up each end of the car and spin the wheels to see if any are binding. Check your tyre pressures. Do you accelerate up to traffic lights and stop signs and then jump on the brakes? Is this mainly city stop start traffic?
https://www.sau.com.au/forums/topic/478598-fuel-problems/#findComment-7915388
How stock is the car?
my ss crewman gets 12/100 pushed it to 16/100 towing, my 32s 20det is better, and a led foot will equal them.
If you were light footed thats bad economy for stock,
Has it ever been modified or tuned maybe for e85 cause that sound like e85 ks to me?
(Not saying put it in and see)
https://www.sau.com.au/forums/topic/478598-fuel-problems/#findComment-7915395
are you sure you are calculating use properly?
should be fill up and zero trip meter. drive around. fill up and record liters used, look at kilometers traveled then do math.
i get a feeling that's not how you are doing it?
  • Like 1
https://www.sau.com.au/forums/topic/478598-fuel-problems/#findComment-7915589
United.. probably a high ethanol blend 95 or 98.  I smell the ethanol in there 91.
Most 95 and 98 contain no more than 10% . Becarefull  if its special blend 98 it could have more.
The pumps need to state when they contain %10 or less. If they dont who knows how much it was blended to meet the specific octane.
https://www.sau.com.au/forums/topic/478598-fuel-problems/#findComment-7915598
And the math is trival. 409.5 km? 50L? The process is 100*50/409.5 = 12.2 L/100km. And that is a perfectly fine consumption rate. More or less exactly what I got on my last tank. Of BP. Never use anything else. Even Shell 98 is not as good.
https://www.sau.com.au/forums/topic/478598-fuel-problems/#findComment-7915602
What worries me is the way he keeps putting 50L in. Does he run it empty and co-incidentally roll in to a service station? I doubt it.
https://www.sau.com.au/forums/topic/478598-fuel-problems/#findComment-7915604
I have 300rwkw and I get 9.8l/100km...…..and I know I get this because I drove to the GC and back.  So 2400km, up the Hume then the Pacific with a bit of messing around first in Penrith then in Parramatta before continuing to the GC.
I drove around the GC a bit going to Wally World's etc, then when I came home I went through to Lismore then up to Tenterfield and back through the west of NSW [Tamworth, Dubbo, Forbes, Young etc].
So not a lot of traffic [but still some], and mainly highway cruising 100 to 120km/h.  Climate control was on, it was warm but not stinking hot.  I reckon if you can't do that with a well set up mildly tuned Gtst then you need to do some navel gazing.
I do have WMI....not sure if this makes a difference though cos I only used 2.5 litres for the whole trip.
Biggest single distance was something like 519km between fills....but that's from memory, I didn't log it.  It was over 500 guaranteed.
https://www.sau.com.au/forums/topic/478598-fuel-problems/#findComment-7915607
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
