Hey Guys
I own a 1997 R33 GTST S2. Recently had a opportunity to fill up the tank and reset the km's
Tank is now empty and Ive done 300km! That is terrible economy. I know its a skyline and i didnt buy it for its thriftiness of fuel but 300km?
Ive heard people doing 450-500 on a tank , this seems to thirsty for me
- Done the 100k service
- Replaced fuel filter
- Replaced o2 sensor
- Havnt been flogging it
What else could cause my economy to be this bad even after I have done the above?
https://www.sau.com.au/forums/topic/478598-fuel-problems/
How have you established the tank is empty? You could have heaps left.
What you now need to do is fill up and figure out the actual consumption, not some random guess based on a 20yr old fuel gauge..
  • Like 1
https://www.sau.com.au/forums/topic/478598-fuel-problems/#findComment-7915334
I get pissed off when mine is worse that 13, driving in heavy stop start traffic. R32 with Neo25DET. It has been running 11s lately.
Heavy fuel consumption is very easy to achieve. Launch it, rev it, drive it around in 3rd when you should be in 5th. Pump the throttle up and down so that you never maintain a steady speed (like 95% of the morons on the road). All these things will make a Skyline suck the juice.
Then there's the mechanical issues listed above.
https://www.sau.com.au/forums/topic/478598-fuel-problems/#findComment-7915363
13 hours ago, Jarvojj said:
I did run it dead empty because I ran out of fuel half away down the road, I rolled it down the hill into the petrol station.
Hang on when did you put in 50L? Had it run out of petrol then too? I am sure your tank should hold more than 50L
Unless you are planning to run it empty again you should fill your tank to the brim and at some point before you run out fill it again and then calculate your L/100km...you may be doing worse than 16.6 L/100
Jack up each end of the car and spin the wheels to see if any are binding. Check your tyre pressures. Do you accelerate up to traffic lights and stop signs and then jump on the brakes? Is this mainly city stop start traffic?
https://www.sau.com.au/forums/topic/478598-fuel-problems/#findComment-7915388
How stock is the car?
my ss crewman gets 12/100 pushed it to 16/100 towing, my 32s 20det is better, and a led foot will equal them.
If you were light footed thats bad economy for stock,
Has it ever been modified or tuned maybe for e85 cause that sound like e85 ks to me?
(Not saying put it in and see)
https://www.sau.com.au/forums/topic/478598-fuel-problems/#findComment-7915395
are you sure you are calculating use properly?
should be fill up and zero trip meter. drive around. fill up and record liters used, look at kilometers traveled then do math.
i get a feeling that's not how you are doing it?
  • Like 1
https://www.sau.com.au/forums/topic/478598-fuel-problems/#findComment-7915589
United.. probably a high ethanol blend 95 or 98.  I smell the ethanol in there 91.
Most 95 and 98 contain no more than 10% . Becarefull  if its special blend 98 it could have more.
The pumps need to state when they contain %10 or less. If they dont who knows how much it was blended to meet the specific octane.
https://www.sau.com.au/forums/topic/478598-fuel-problems/#findComment-7915598
And the math is trival. 409.5 km? 50L? The process is 100*50/409.5 = 12.2 L/100km. And that is a perfectly fine consumption rate. More or less exactly what I got on my last tank. Of BP. Never use anything else. Even Shell 98 is not as good.
https://www.sau.com.au/forums/topic/478598-fuel-problems/#findComment-7915602
What worries me is the way he keeps putting 50L in. Does he run it empty and co-incidentally roll in to a service station? I doubt it.
https://www.sau.com.au/forums/topic/478598-fuel-problems/#findComment-7915604
I have 300rwkw and I get 9.8l/100km...…..and I know I get this because I drove to the GC and back.  So 2400km, up the Hume then the Pacific with a bit of messing around first in Penrith then in Parramatta before continuing to the GC.
I drove around the GC a bit going to Wally World's etc, then when I came home I went through to Lismore then up to Tenterfield and back through the west of NSW [Tamworth, Dubbo, Forbes, Young etc].
So not a lot of traffic [but still some], and mainly highway cruising 100 to 120km/h.  Climate control was on, it was warm but not stinking hot.  I reckon if you can't do that with a well set up mildly tuned Gtst then you need to do some navel gazing.
I do have WMI....not sure if this makes a difference though cos I only used 2.5 litres for the whole trip.
Biggest single distance was something like 519km between fills....but that's from memory, I didn't log it.  It was over 500 guaranteed.
https://www.sau.com.au/forums/topic/478598-fuel-problems/#findComment-7915607
    • It's impossible to convey what it will feel like to get the right torque. But you can develop a feel for it. A 900mm breaker bar is.....f**king huge. I only use a normal ~400mm one. But with 900mm being very nearly a metre, and the right torque being in the order of 100Nm, then you're going to need a bit over 100N of force, which is about 10 kg. So if you practice using the bar pulling up, instead of pushing down, then it will be about the same effort as lifting a 10kg bucket of water. That's what the pressure against your fingers should feel like. Ish. If you use a more typical length breaker, then it's about twice that. So a good 20 litre bucket, or a little bit more.
    • Also, if anyone has a torque wrench around Williams Landing area and can lend it to me for like 5 mins - I got 4 bottles of Furphy left and I’ll throw that in with a Happy meal 😂
    • So today I decided to bleed my brake fluid, which meant to the wheels came off the car at my garage for the first time. I only had a 90cm breaker bar with me and I noticed that some 1 or 2 lug nuts were a bit hard to get loose (from when the shop did the coilovers) Now.... when it came to putting them back on, I didn't want to put all my weight and overtighten them. So I hand tightened as much as possible and then put normal pressure on the edge of the breaker bar and tightened it until I couldn't turn it anymore without putting in an effort. Do you think that is tight enough? Or is that still too tight?  They are tighter than finger tight. Last thing I want is to have them strip or warp sh*t. But hard times mean I can't just go down to Supercheap and get a torque wrench 🥺
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
    • I don't think that's what you're seeing. Something else doing that. The only time I've seen it get so retarded is when it's trying to control idle (in which case we're not talking about mapped timing tagets anyway) and when there is an extreme coolant temperature sensor fault. The RB26 ECU is essentially the same as the 20 ECU and I knew that ging inside out. There is no facility for it to retard that heavily on cold start. The OEMs never used to do it back then. I mean, shit, the catalyst is abotu 3 miles down the exhaust anyway. Early light-off was just a twinkle in some EPA arsehole's eye back then, not a regular engine control strategy.
