1. Pair of Greddy cast manifolds from their VQ35DE 350z kit as seen here https://www.z1motorsports.com/forced-induction/greddy/greddy-twin-turbo-kit-350z-intercooler-p-6566.html
$500
2. Cusco OS front strut brace part number 288 540 a as seen here https://conceptzperformance.com/cusco-type-os-front-strut-tower-bar-brace-infiniti-g25-g35-g37-q40-q50-q60-ex35-288-540-a_p_9888.php has been used
$150
3. ATS Carbon 1.5 way diff centre suit Z33/Z34/V36 diff according to Japanese seller. Part number CNRB109130. Purchased second hand from Japan, never used in Australia
$800
4. Z34 vq37 HKS oil cooler kit part number 15004-AN024. Purchased second hand from Japan, never used in Australia
$650
5. Greddy easy camshafts to suit VQ35HR brand new. Direct replacement for standard
$800
6. V36 sedan late model factory front lip used
$250
7. M35 Stagea tail light covers. Used, Factory silver minor damage to bottom one (inside corner chipped).
$100
All prices are negotiable for quick and easy sales. Located in Adelaide, shipping at buyers expense.
Plenty more pics available on request.
Edited by M I K E
M35 tail light covers added
https://www.sau.com.au/forums/topic/478600-vq-upgrade-parts-for-sale/
Also have a pair of genuine fog lights with Nissan part number 26150-8990B, were advertised as "V36 E11 T31 C25 C11 Genuine Fog Lamp L/R Set" when I bought them but fairly certain they will fit other models (check p/n)
$150
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
