Okay so im not very good at electrical stuff with cars and ive searched for a solution on the web but have gotten no clear answer.    I was driving to work on the highway and everything is normal and suddenly I hear a loud pop and the dashlights get very bright then back to normal (this is at night by the way) and the background noise from the stock amp gets louder and sounds more erratic but the speakers and everything still works fine, then the hicas light starts flashing on and off every minute or so. Nothing else happens I park at work and shut it off, get back out to the car after and its totally dead nothing works.  I jump it and it starts no problem and the hicas immediately starts flashing faster and faster and I can hear some motor in the back turning off and on in sync with hicas light, and the power steering also stops working everytime.  it does this till I turn the car off hoping that the hicas turning on and off didnt damage anything.  Car is now dead again. Jumped once more and it runs rough for about a minute before stalling. I think maybe the amp blew and its drawing power or malfunctioning somehow when it shouldnt be so I cant figure out how to unplug it so I pull the amps fuse and jump it and it starts but not a single light in the interior will turn on in the dash or anything except headlights and I can give it some gas but i hear the hicas going wild in the back still, car stalls so I unplug hicas ecu and jump the car again and the lights are on and the hicas has stopped and no hicas light. Car still stalls after a few minutes. I jump it and let it charge for a few minutes then try and gun it home with high rpms and everything is working fine till suddenly 10minutes later a loud pop and dash lights flash bright then back to normal and the car starts slowing everything else working normally till I come to a stop then it all shuts off at once.  So have had it towed home and checked the battery with a multimeter and it reads 11.55v off and on and with the car revving it drops to like 11.40v  The loud pop sounded like it came from speakers and happend in sync with dash lights messing up. Anyone that knows anything about this cars electrical would be a massive help in diagnosing this.   Its a 1991 r32 skyline gts4. I suspect could be bad alternator or amp is drawing too much power now or hicas is being weird or bad battery.   Id say alternator right away but idk why the hicas and speakers would go wild together after they popped if it was the case. This pop happens even with the speakers off btw.
Also forgot to add the tach doesnt work or any gauges besides fuel gauge when the dash lights go out. Which currently they are out and no electronics in car work except headlights but it will start and run under its own power with a quick charge.  Not sure if its still stalling havent tested that yet.
Almost forgot to add sometimes the electronics and dash start working again and stay on if i rev the car to about 4or5k rpms and then let it idle they will be on till the car stalls again
Edited by TheOrangeSkittle
Sounds like your alternator is stuffed. The regulator in your alternator is overcharging >16v (dash lights getting brighter ) and undercharging <12V causing all your electronics to play up. By disconnecting the amp and the Hicas ecu,  you're effectively lowering the load (electrical output) on the alternator.   You probably blew a few fuses in the meantime. I'd be getting the battery tested and your wiring (to the amp) checked. The noise coming from the amp sounds like electrical inteference. It is stalling because the alternator can't keep up the voltage supply after you jump start it. You'll need a new alternator, or have an autoelec rebuild it. Best to fit a new battery while your at it. And check all your fuses and fusable links. Good luck.
Hello and thank you its what I thought it was too just never had this many weird problems with an alternator going bad.  Also the lights on the dash and the tachs dont work currently but occasionaly they will flicker when starting the car but not stay on. Could this be a fuse problem or would simply replacing the alternator fix this. Also the car is driveable just no turn signal or interior lights or anything. basically the only thing working is engine essentials and the headlights.
1 hour ago, GTSBoy said:
Almost all of the electical systems in your car at at risk of death from the voltage regulator failing
Yes to all, My three series BMW did exactly what you described some time ago and it was the voltage regulator, but It fried the battery, the TCU and the ABS computer, So straight to the auto electrician is best advice and get the entire system checked.
yes I had it towed back home and charged the battery, the hicas should be okay since I disconnected it the first time it was acting up when I charged the car and pushed it into the garage I started it one last time to see if the lights work and they all flickered on and stayed on so I just shut it off and am gunna wait till I can get it to someone to replace the alternator, I know a mechanic like 5 houses down who may be willing to do it and theres a more high end garage abit further that im sure can deal with it. The time I did use it was mainly test driving it around the parking lot for a minute and a short 5min attempt on the highway, everything on it seems to work properly still so Ill do like you all said and leave it for a pro thank you all for the help!.
Hello so update on all of this im pretty sure my problem has been fixed. Took it to a guy familiar with skylines and he found the alternator did indeed crap itself and found charring on the internals along with a faulty connector and a bad fusible link that he discovered had already seperated but previous owner soldered it back together probably because he couldnt find another to replace it.  And it also had a bad battery so new fusible link plus re pinning the connectors with a new alternator and new battery seems to have fixed all issues. The car seems to even run smoother now than when I first got it. Thanks for any suggestions you guys gave!.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
