Hi guys
Keen to hear where you guys service or recommend servicing the V36 - I am looking for a mechanic for our imported Nissan skyline. Someone who knows about the V36 and can help sourcing parts if needed. We need to replace the breaks at the moment however, local Nissan mechanics at Brookvale don’t seem to know about imported Nissans and hasn't been much of a help. In past we mostly got it serviced at Infiniti Centre at near city (the guys were really helpful getting parts imported / fitted) however that centre closed a few years back.
Thanks!
Any decent mechanic should be able to look after a V36. Just tell them it is a long wheelbase 370Z and they should be okay from a mechanical point of view. Brakes can be a little tricky as there were 3 types of front brake, but it comes down to either single piston, dual piston or the huge 4 pot ones. Each uses different discs.
10 hours ago, protik said:
Hi guys
Thanks!
What brakes do you have?
Brake pads and rotors for base model or akebono are super easy to come by.
Just as an example I called up the Infiniti Service Centre Warwick Farm today to book in the car and the feedback (which is similar to what Nissan Brookvale told us as well) was that since it's an imported vehicle they can't use the VIN number to look up which "genuine" parts are needed for the car and hence don't want to go back and forth trialing different parts which is consuming / expensive (they will however service the car if we can source the parts needed first).
Is there an official catalog that lists all the parts for the 2008 Skyline 370GT (V36) so the mechanic knows what to order in? Unfortunately I don't have much experience when it comes to car parts so if any such catalog to provide the mechanic or mechanic recommendation in Sydney that would be very much appreciated.
Cheers
Cheers
99% of 370z parts are for v36 aswell.
Or put your chassis numbers into partsouq website and find all the oem parts yourself
Protik, whatever I can't handle in my own driveway, I get my longtime mechanic Adrian at Adrian's Auto Centre at 100 Parramatta Rd Croydon to handle it for me instead. Knows his stuff.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
