Okay so I brought a r33 auto Rb25de+t and it drives okay but if I take it to 5500 revs it misses then dies. It sounds like it's not getting enough fuel? Ive checked my fuel pump and it's a Rb25det pump and Got new coils but the miss is still there. I've got a spare pink afm I wanna put on but I'm not sure if all pink air flow meters are the same? It's off a 20e so I'm not sure it would work. I'm gunna buy new injectors next and see if that helps. Anyone had the same issue and fixed it? S2 rb25de plus t auto
https://www.sau.com.au/forums/topic/478620-rb25det-missfire-help/
I had a very similar issue with mine and it was the Afm that caused the issue. As far as the afm I wouldn't be confident a 20e afm would be the same as a turbo one.
10 hours ago, Rusty Nuts said:
Don't go buying new injectors, go borrow a portable wide band o2 and actually see what's going on before you go aimlessly burn cash.
If not pay some workshop $100 and run it up on a dyno and see what is going on.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
