Hello. I own an RB25DET swapped 1989 240sx and I've been having trouble with the speedometer. Whenever I'm driving, it seems to work, but it only works up to roughly 15 mph. The lights such as seat belts, fuel lights, door lights, etc. work correctly. The tachometer works fine as well. Any guidance will be greatly appreciated.
Thanks, Jason.
https://www.sau.com.au/forums/topic/478624-240sx-speedometer-issues/
OK, so do some searching on here for the many words I have typed on the subject. Particularly you are looking for mentions of square wave and saw tooth and 0-1v and 0-5v and speedo and sender and so on.
What I have written is largely true for R32s and R33s. I do not know anything about the S chassis speedos. I am under the impression that they used electronic senders and so they should work similarly to the R33 type stuff. But they may not. You should use what I have written on SAU as a primer to help get you started understanding how these things can work, and should use it is guidance for what to look for in how the S chassis stuff works.
Edited by GTSBoy
  • Like 1
You require a speed signal converter as the signals are different. Dakota digital do a converter or if you are keen to be covered in gearbox oil, swap in the original sender unit cog/drive onto the Rb25 sender as has been known to work on other Nissan gearboxes.
http://www.nissansilvia.com/forums/topic/381889-rb-box-in-s13-how-to-get-speedo-to-work/
https://sxoc.com/vbb/archive/index.php/t-460010.html
Edited by robbo_rb180
Links added
    • Hey guys I’m chasing a Rb20det complete or bare block need a good running engine as mine has low comp
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
    • 98 and 95 have to meet the same national fuel standards beside the actual RON.  91 has lower standards (which are quite poor really), so 95 is certainly not 91 with some octane booster. It would be an easier argument to claim 98 is just 95 with some octane boosters. Also RON doesn't specify 'quality' in any sense, only the octane number.  Anything different retailers decide or not decide to add to their 95 or 98 is arbitrary and not defined by the RON figure.
    • Anyone know alternatives to powerplus tungsten? Can't find an alternative online.
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
