Clutch switch? Come again? ?
Neutral switch, the guide on here says not to connect to the auto ECU which I still have. But others say to connect it. IACV was cleaned when it was still auto. Never had issues with it. This has only started after the conversion. No wiring other than the inhibitor switch was touched.
Why are you laughing. The clutch switch and the neutral switch are used by (manual) ECUs to help inform them of what you are doing. This is particularly the case where you are rolling along with a non-zero speed in either neutral or in gear with the clutch depressed. The ECU will keep the idle speed higher, to make it easier to clutch out and get moving again. Lack of these inputs tends to be a significant contributor to the idle-drop-and-stall that often happens on half arsed conversions.
Both these are hooked up on my auto-man converted R32. Was true using the original RB20 (auto) ECU and is also true using the RB25Neo (auto) ECU that is in it now. I can see the signals for them come on in Nistune.
My s2 c34 rs4s type b Definitly did not have a factory clutch switch.
12 minutes ago, Tosseef said:
Neither does my S1.
Which was an auto?
are you using an auto or manual ecu?
can guarantee the calibration is different for idle amongst other things
  • Like 1
I'm using an R33 GT-R pedal which needed modification to fit. When bolted flush to the firewall it also depressed the rod which gave me clutch slip on idle. So I put 10mm spacers behind the pedal and wound the adjuster rod out bit by bit till I got a full clutch engagement and disengagement. Car's been fine ever since. Although the revs do spike when the clutch is depressed. So will be wiring the neutral switch back in.
    • Be more active mate.. , not taking the piss ❤️, your long term health will love you for it I would think something like a kettle bell or 2 laying around in areas you go past during the day would be awesome for ADHD.... "Oh look, a kettlebell", and exercise helps your brain health as well My mates son was a bit of a problem child, diagnosed wirh ADHD, and some other things that had his brain occasionally doing loops, until we got him into a training program, the difference after he started training was amazing, he had more focus, and his fitness levels exploded, it is like he is a totally different kid to be around Brain chemistry something something Stay fit stay strong mate
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
