Clutch switch? Come again? ?
Neutral switch, the guide on here says not to connect to the auto ECU which I still have. But others say to connect it. IACV was cleaned when it was still auto. Never had issues with it. This has only started after the conversion. No wiring other than the inhibitor switch was touched.
Why are you laughing. The clutch switch and the neutral switch are used by (manual) ECUs to help inform them of what you are doing. This is particularly the case where you are rolling along with a non-zero speed in either neutral or in gear with the clutch depressed. The ECU will keep the idle speed higher, to make it easier to clutch out and get moving again. Lack of these inputs tends to be a significant contributor to the idle-drop-and-stall that often happens on half arsed conversions.
Both these are hooked up on my auto-man converted R32. Was true using the original RB20 (auto) ECU and is also true using the RB25Neo (auto) ECU that is in it now. I can see the signals for them come on in Nistune.
My s2 c34 rs4s type b Definitly did not have a factory clutch switch.
12 minutes ago, Tosseef said:
Neither does my S1.
Which was an auto?
are you using an auto or manual ecu?
can guarantee the calibration is different for idle amongst other things
  • Like 1
I'm using an R33 GT-R pedal which needed modification to fit. When bolted flush to the firewall it also depressed the rod which gave me clutch slip on idle. So I put 10mm spacers behind the pedal and wound the adjuster rod out bit by bit till I got a full clutch engagement and disengagement. Car's been fine ever since. Although the revs do spike when the clutch is depressed. So will be wiring the neutral switch back in.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
