New fan hub and fan for RB25DET Neo. Will likely bolt onto other RB20 RB25 and RB30.
You may notice the fan looks a little busted up. While new, it did have an enounter with an engine cover, and the engine cover lost.
However it still keeps temps down at the track and works perfectly and has no cracks whatsoever.
If you are fancy you could sand down the rough edges of the fan with some sandpaper. Or just flat out not use it as the hub itself is well worth it alone relative to a brand new one which this one basically is.
https://www.sau.com.au/forums/topic/478672-rb25det-new-clutch-fan-hub-and-fan/
You have not gone blind. I have gone blind. I wanted $250 for the lot. Note: The price from Nissan for both items via Kudos or Taarks is ~$550.
  • 3 weeks later...
