Whats your Run around?
BarnyR32
 Share
Hey Boys/Girls,
I havent seen a post like this so i thought i'd throw the key into the ignition and start one up!!!
What run around vehicle/bike/animal do you use when your not driving your skyline?!!?!?
I my self have a 1995 charade, which i use to get to and from work mon-fri...
all i can say is, its abit different from my line...haha just a tiny bit...
:P
  • Replies 43
When I'm not in the Skyline I'm out on the bike - 2001 Honda CBR929RR FireBlade. It's an Erion Racing model too, which I'm told has bigger cams, modded ECU, and a couple of other tweaks to give it a few more hp.
Bucketloads of fun, uses about half the fuel of the 'line, pops off-the-throttle monos at highway speed, and sounds really angry over 9000rpm :cheers:
Pictures HERE
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
