So I just finished installing my new clutch kit on my rs4 stagea, gear box is in and bolted up. The car comes with basically the same gearbox as a 33 gtr with a pull style clutch. I was just about to put the slave cylinder back on but realised that I could slide the clutch fork along the input shaft with no resistance. after getting some light I could tell that the throw out bearing isn’t locking in to the retaining clip on the pressure plate like its meant to. whenever I pull back on the fork it basically just pops right out with minimal force. I’m not sure if I’ve just damaged that little clip along the way somewhere or its defective. So is it possible to just buy a new clip from the manufacture?? Or maybe I’m just missing something is there a special way to get it to engage or something????? Pls help thanks
