Hey all,
I'm currently underway with a complete nut and bolt re-build of my R32.
The car is now fully stripped. 30 years of driving and weather meant that almost every bolt under the car was as good as welded on and required/will benefit from replacement. Breaker bar ftw.
I've downloaded the workshop manual, which is great in terms of displaying every part (including every nut and bolt and their nm specs. Handy.) but it doesn't show their dimensions (thread gauge, length, socket size etc).
Do we know if there's any resource which lists this information? Similar to the workshop manual, I'd ideally like to be able to look at a schematic, note all the bolts I'll need, then buy them.
Please don't assume I was diligent enough to keep each nut and bolt and list their location, so I could refer back to them. They're all in the bin and let's just put that down to my stupidity and impatience. I have, thankfully, properly photographed, listed and numbered all of the parts, but the bolts escaped my attention.
Off the back of that, does anyone have any sources they can recommend for purchasing very high quality nuts and bolts (e.g. Wurth etc).
As always, thanks in advance for your advice.
Andrew.
https://www.sau.com.au/forums/topic/478705-r32-gtr-bolt-sizes/
44 minutes ago, djr81 said:
You best resource is the part numbers etc which you can then match up to what you have.
63306-2_8.jpg.72ebb635bb0f07255c328c32fe6cc1a0.jpg62005-2_9.jpg.758d176f1a2e906fa3022edbd2f7a2fa.jpg
Thanks! How would I then match up the numbers? i.e. is there another online resource which then gives the info on the specs, or would I need to go to Nissan with the numbers?
Not really, or atleasst not that I know of.  Start here:
https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/skyline/BNR32?ref=ae
So you may want bits for the door, for example.
https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/skyline/bnr32/3891-rb26dett/body/800
This lot are useful too.
http://www.kudosmotorsports.com/catalog/nissan-skyline-c-21_22_25.html
The trick, such as it is, is to use the suffix 05U00 where appropriate.  Also the nengun rendition of fast is better resolution.
https://www.nengun.com/oem/nissan/skyline-gt-r-bnr32
Edited by djr81
Sorry to be negative....but you are a bit stuffed.
The only information on bolt length is in some specific cases in the workshop manual where it matters, eg oil pump bolts.
There is also some information on generic torque specs at the front of the manual for bolt sizes, but the individual diagrams show the actual torque for each application.
In nissan bolts of that age:
m6 - 10mm head
m8 - 12mm head
m10 - 17mm head
m12 - 19mm head
not much under m6 or above  m12 but they are generally 8mm or 21mm.
As for bolt pitch, they are almost always standard (coarse), but the gearbox cross member ones are fine pitch. Coarse vs fine is a standard for metric bolts that varies depending on bolt size (eg m8)
As for length, no such doco unless there is something specific in the service manual. Also there are some bolts like the rear shock lower arm or rear control arm upper arm inner bolts that are specific (shock bolts have a conical end to assist insertion, and upper control arm inner bolts have camber adjustment).
I know you can't undo it, but.....KEEP YOUR BOLTS NEXT TIME!
1 hour ago, GTSBoy said:
Going to be the first time that anyone has bought a wreck just to get all the fasteners!
lol I had to double check my post because I thought about suggesting that, then didn't. But with 32 gtr prices these days maybe a gts4 half cut would be a cheap way to fix the problem.
Thanks for all the input, guys.
I have access to other 32’s, so I can get the specs from there. I’ve kept everything under the car from the front cradle back, so that’ll be fine and everything engine related will be new anyway, so that won’t matter.
I’ll make a list of all the relevant dimensions and their locations, then post the list here for others in the future. There will only be more people wanting to do complete nut and bolt resto’s moving forwards.
Edited by Veilside R33
It is well worth getting hold of a copy of FAST so that way you have a full reference for the car. Once part codes have been converted into part numbers you can search for them on Nengun, Amayama, Kudos, Patsouq etc as @djr81 has mentioned above. I have had the most success on Amayama lately.
If your old bolts are still serviceable  - just surface rust etc  - and except for critical once use only applications - I'd consider sending them off to a bright zinc finish plater like A+G Platers in Belmore?? [been a while since I used them] Sydney.  Be much cheaper and easier.....plus if you combine that with buying some new ones then you will have a great supply to choose from for all your applications.
Used to be able to get a bucket of bolts done for around $100 from memory.
Big fan of zinc plating and I'll be doing it on a few parts (hood catch assembly etc) but most of the bolts aren't in perfect condition and my OCD and the level of build quality I'm aiming for won't let me do it *sigh*
Had a good look through the amayama and nengun links today and they'll give me exactly what I need. Everything is still fresh in my memory from the strip down, so I can just look at the exploded diagrams and I know which bolts I need (erm, all of them).
Thanks again everyone!
Yeah, I've done it for other builds where standard bolts and bolts with standard head markings were no longer available, but preparation is the key.  Hours on the wire wheel cleaning the threads up, on the TIG welding up the corners, and on the Dremel sanding the flats etc before getting them plated.  But it was worth it for that fresh/new standard look.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
