I was wondering if anyone here has had to trailer an R34 GT-R before? I'm from the US and as most of you probably know they're generally illegal here until they turn 25 years old but there are a few exceptions under our Show or Display law. I bought one of those eligible cars and currently have it stored in Canada until next year when I can bring it in. Once it's legal I'll need to trailer it since it's 2500 kilometers from where it's at to Arizona where I live. Needless to say there aren't many people I can ask here in the US who've had experience securing an R34 on a car trailer before so I was hoping someone here could give advice. I've trailered my R32 before when it needed to go to a shop for work but I don't know how the R34 compares in terms of attachment points for straps, clearances, and such.
When I trailered my R32 I used an open U-haul trailer with front tire straps and then used Vulcan rim straps crossed in the rear and everything was nice and secure - that was for trips about 320 kms long. For the R34 since it'll be a much longer distance I'll probably be renting an enclosed car trailer for weather protection and security (especially since they're so rare here in the US that it'll probably be an attention magnet on the way down).
Any tips or insight you guys could give as to the best way to secure the car on a trailer would be greatly appreciated. Thanks in advance.
https://www.sau.com.au/forums/topic/478743-trailering-an-r34/
Nothing particularly tricky about an r34 compared to anything else, unless it is a vspec with the carbon fibre undertrays in place which would make it much harder to get to chassis tie down points. (eg, around the rear subframe)
These days I always just use wheel tie downs, I have an open trailer and they are very quick and secure. Unfortunately if you are using an enclosed trailer you will be somewhat at the mercy of the available tie down points in the trailer, and depending on width it can be hard to get to the wheels to tie down there
Thanks for the input. I hadn't thought about that with the undertray. Like Mark said, it's a V-spec since only the MP2 V-specs like this one I have or an M-Spec Nur are legal for US import right now (although the latter will remain much more of a hassle until 2023).
The trailer I'm planning on renting will be an 8.5x20 ft model with both D-rings and E-track so hopefully I can just do something like this without too much hassle:
4 hours ago, GTSBoy said:
Straps up and over the tyres, like a tow truck, is the most secure.
Agree this is the best and quickest way if the trailer is set up for it.
Otherwise, I tie it exactly as per your pic
On 9/20/2019 at 11:46 PM, GeeDog said:
I use 4 of these:
Tyre strap
Along with 4 x 2500kg ratchet straps - one on each wheel.
Haven't seen those before. Those look really handy. I'll have to see if I can get some over here in the States.
Okay, thanks for the additional input! What I'll probably do is get a least a pair of over-the-wheel straps for at least the front to go with a set or two or lasso and/or rim straps for all four corners as added insurance.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
