Hey All!
Wondering if anyone can help me, had some rain here recently and noticed water got into the cabin. I'm pretty sure it happened while it was parked and not driving. It's only in the driver side footwell and I've checked the fire wall and there is no obvious place for water to enter (such as a grommet or such.
Have pulled the carpet back and it looks like it's leaking from the centre console maybe? Just wondering if anyone has had a similar issue or has any thoughts on where this could be from?
The water patch seems to be from the left of the clutch pedal against the gearbox tunnel (can see the discolouration on the photo.
Any help would be sooo good :) (is in a R34 GTT)
Edited by Tobz
https://www.sau.com.au/forums/topic/478751-water-leak-to-cabin-any-ideas/
7 minutes ago, GTSBoy said:
  • Windscreen seal.
  • Plenum chamber drains blocked.
Makes sense. I'll try and see if either of those are the issue.... Is there an easy way to check either? I had a look at the windscreen but it's hard to tell if the seal is 100%
I'll have a bit of a google
@GTSBoy
Ok pulled the car apart, finally have located the rough place of the water entry
The water seems to be dropping from above the throttle pedal. I'm thinking it's the windscreen?
Also cleaned up what I think are the plenums? They had leafs but nothing major. Picture also attached
Edited by Tobz
1 hour ago, GTSBoy said:
There's so much visible rust there that the windscreen lip is bound to have rusted.
It was all just black grime there, took me 20 mins to clean it back to this. Will probably sand it back and paint it up later this week
If it is leaking at the firewall near the accelerator then you have to take the front wheel off, then remove the plastic guard liner [screws and clips].  Behind this there are a few grommets and such for gauges and cables etc.  You won't see these grommets in the engine bay.  I'll bet that one of the grommets has been split for aftermarket gauges or boost controller.  Silastic out of a caulking gun works.....well did for me....but that was almost 20 years ago.
  • Like 2
Cheers! I'll try that first before the windscreen! Worth trying the cheaper options first!
  • 4 weeks later...
Ive had this problem as well but only happens when driving in the rain
  • 2 months later...
It was 100% this. Took me a while to get to it, but pulled it apart and found that the guys who did the alarm used the grommet there and just used masking tape to cover it. Tape loosened and formed a funnel which flowed the water into the cabin. Used some loctite putty thing and sealed it up good!
  • Like 1
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
