I've read and searched but can't find too many answers as most seem to opt for 1000cc injectors
Basic run down - HKS 2535/550cc KPM Injectors/Walbro 255 pump - 260kw at 18psi now
I never planned on using E85, however plans change :) My plan is just to fill it up with E85 and see where we get with the tuning
Given the turbo hasn't got much left in it, what's people's thought's on this being enough?
They are too small, unless you bump up the base fuel pressure to 4 bar.
You'll need about 35% more fuel flow. Say if you're already at 80~90% DC then you won't have headroom for E85.
You'll be able to get more power out of your setup, as I can imagine you're pretty knock limited on 98RON with that small turbo. Don't expect miracles but a 10~15% gain in power is possible :)
ID1050x still has a very narrow spray angle, most of the fuel will go straight down the intake divider. Toyota made that work by using air assisted fuel injectors but as far as I know the RB26 has no such system and is much more reliant on the injector itself providing the spray pattern and atomization. Bosch motorsport has the 040 980cc injector which works great, just make sure you get a flow matched set.
  • Like 1
They also don't mind high rail pressure too, at 4bar they become "1150cc" as most retailers advertise them at which is misleading. Just like how plenty of eBay retailers called the Bosch 1550 a 1650cc injector
  • Like 1
I had 257 kw using 98 fuel: 525cc XSpurt Injectors and 255 LPH Pump at 20~18 PSI.
Told my tuner I just wanted E85 and see what it can do.
Tuner said not enough fuel pumping and had to upgrade to Walbro 416 LPH .
End of the day it made 295 kw 21PSI on E85 using 525cc Injectors at 100% duty cycle
In my experience, never go weak on fuel. I now have XSpurt 1000cc + 2xBosch 044's in a surge tank, the same 416 pump in the stock tank. Don't limit yourself just to upgrade it again later :D
Edited by statue
  • Like 1
With the caveat that too much/many pumps leads to fuel heating problems unless you put the effort in to control the pumps properly.
Got to 278 without too much hassle, swapped the pump out to a Walbro 460lph unit prior to tuning
As per most E85 results, picked up power and torque everywhere. Still some more left in it if I really wanted to squeeze it, but the tune was done with some upcoming track days so it's reasonably conservative
Happy with the results given the basic mods it has
good results, you appear to have very similar mods to my track car so will be interesting to compare, which dyno in Adelaide is this on?
Boostworx does all my tuning
  • Like 1
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
