I've read and searched but can't find too many answers as most seem to opt for 1000cc injectors
Basic run down - HKS 2535/550cc KPM Injectors/Walbro 255 pump - 260kw at 18psi now
I never planned on using E85, however plans change :) My plan is just to fill it up with E85 and see where we get with the tuning
Given the turbo hasn't got much left in it, what's people's thought's on this being enough?
They are too small, unless you bump up the base fuel pressure to 4 bar.
You'll need about 35% more fuel flow. Say if you're already at 80~90% DC then you won't have headroom for E85.
You'll be able to get more power out of your setup, as I can imagine you're pretty knock limited on 98RON with that small turbo. Don't expect miracles but a 10~15% gain in power is possible :)
ID1050x still has a very narrow spray angle, most of the fuel will go straight down the intake divider. Toyota made that work by using air assisted fuel injectors but as far as I know the RB26 has no such system and is much more reliant on the injector itself providing the spray pattern and atomization. Bosch motorsport has the 040 980cc injector which works great, just make sure you get a flow matched set.
  • Like 1
Expand
They also don't mind high rail pressure too, at 4bar they become "1150cc" as most retailers advertise them at which is misleading. Just like how plenty of eBay retailers called the Bosch 1550 a 1650cc injector
  • Like 1
I had 257 kw using 98 fuel: 525cc XSpurt Injectors and 255 LPH Pump at 20~18 PSI.
Told my tuner I just wanted E85 and see what it can do.
Tuner said not enough fuel pumping and had to upgrade to Walbro 416 LPH .
End of the day it made 295 kw 21PSI on E85 using 525cc Injectors at 100% duty cycle
In my experience, never go weak on fuel. I now have XSpurt 1000cc + 2xBosch 044's in a surge tank, the same 416 pump in the stock tank. Don't limit yourself just to upgrade it again later :D
Edited by statue
  • Like 1
Expand
With the caveat that too much/many pumps leads to fuel heating problems unless you put the effort in to control the pumps properly.
Got to 278 without too much hassle, swapped the pump out to a Walbro 460lph unit prior to tuning
As per most E85 results, picked up power and torque everywhere. Still some more left in it if I really wanted to squeeze it, but the tune was done with some upcoming track days so it's reasonably conservative
Happy with the results given the basic mods it has
Expand
good results, you appear to have very similar mods to my track car so will be interesting to compare, which dyno in Adelaide is this on?
Expand
Boostworx does all my tuning
  • Like 1
    • Dang I looked at this for so long until I realised it was for the inner rod. I was so confused. This looks like a great tool. Another injected plastic box for my collection. I for one am a torquer. I'm far too anxious and neurotic to not use the correct torques whenever I can. I do honestly feel like my wheels will fall off if I dont.
    • Not sure if you're being serious? I, and all the car people i know, ALWAYS use a torque wrench for wheel nuts. I assumed any car person, apart from tyre centre monkeys with rattle gun in hand, would do it properly.  Anyway, no further reply from me on this unless legit discussion from OP or his query so, over to you, knock yerself out.
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
