Hey guys, I’ve been trying to set my TPS on my RB20DET R32 GTS-T,  however, the lowest voltage I seem to be able to get is around 1.5 and the highest being around 3 (fully tilted each way). Does anyone have any idea why I’m unable to get any readings anywhere near 0.48 where it needs to be? It’s driving me crazy.
Ive tried changing out the TPS for another one but still get the same exact issue, I’ve attached a video for reference.
Any help is super appreciated!
1513450E-9D8C-4B2D-905A-5493631D8083.MOV
Edited by NathaNZ
https://www.sau.com.au/forums/topic/478787-tps-voltage-issues/
Are you aware that the RB20 ECU gives no fark for the TPS voltage? It's not an RB25.
The RB20 uses the closed throttle switch and the 100% throttle switch. The potentiometer output on the TPS is used by the TCU only.
Stop trying to set it the way that you do for an RB25.
The correct approach is to adjust it so that when the engine is running at idle, when you _just_ tweak the throttle open the tiniest amount, the ECU will double pulse the injectors. You can hear them make a click-click noise when it happens (over and above the steady clicking rate at idle).
Cheers for that GTSBoy, I honestly had no idea. :)
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
