Hey guys.
Had a question on the Apexi PFC. Picked one up and it's on the way. I have found the software through the forums, but unsure if the version 2.132 is the most up to date. Is it?
2nd question is do I absolutely need the FC Datalogit to have the Apexi PFC interface with the computer/software and the cable to be able to tune it?
Appreciate the help in advance.
Edited by Jjtxaz24
https://www.sau.com.au/forums/topic/478792-apexi-power-fc-with-controller/
Yes you do need FC Datalogit to tune it properly, with the hand controller you're missing out on many tables and functions.
Also, just curious, why did you decide to buy a PowerFC in 2019? They're so outdated, low in features, doesn't' support flex, doesn't support triggering changes, doesn't do heaps of things actually.
The software 2.132 is the FCdatalogit software and is the last release from over 8 years ago. To connect to ECU you need the FCdatalogit input expander box, or FChako interface cable.
I realize it was a bit older. I'm not gonna build the car all out. I wanna have a little more HP on tap and hang with the locals around here (lot of domestics Mustangs and Camaros that run their mouth) I want to rebuild the stock turbos with some good turbines or if I can find some other turbos for a good price I'll go that route, add a set of cams, a good, less restrictive exhaust and that's about it. I still need lot of maintenance on it to make sure it's a solid daily driver.
It was what was affordable and within the budget for me to be able to start getting some fun parts into the GTR. I also saw the Nistune (seems like it's really out dated too) and a guy here locally said he could tune with that one after I had purchased the PFC. I'm located in the US by the way.
Ok so I have the proper and "current" software. I'll look into that FCHacko interface cable.
No, not outdated. Uses the original ECU, which is a really solid choice for a lightly modded engine, because the Nissan ECU already knows how to make the best use of the CAS signal, idle control, etc etc. On top of that, Matt @ Nistune is constantly developing the product, and it can do all sort of things that used to be only able to be achieved with expensive aftermarket ECUs. You can have flex-fuel now, for example. Nistune is a bit limited compared to very modern aftermarket ECUs, but I would choose (and have chosen) Nistune of PFC every single time.
Edited by GTSBoy
  • Like 1
Although not as modern as some of the full standalone it has it's merits as @GTSBoy has pointed out.
Also it's easier to setup with larger injectors (thanks to the TIM) and you can run the R35 MAF card with a drop down (where as in a PowerFC have fun scaling it). Not to mention it has basic launch control, basic TP Load and water temp engine protection (neither of which the PowerFC has) and flex fuel support, with reverse flex fuel support, i.e. primary map is E85, compensation table is 98RON but wait there's more, you can actually change the blend amount too between the primary table and the compensation table.
So good.
Couldn't agree more with Dose and GTSboy, i'm using a Nistune on my GTR which puts out over 400rwks (550 ozzy HP) to the wheels...
I'm using the flex feature as well as boost control all now within the ECU...
I've just bought a track car which came with a Link G4+ and I am very impressed with it's features but if i'd have been starting from scratch on this car I still probably would have gone the Nistune for my needs...
So good.
Well dam.
A fraction of the price and had just what I needed. Hope it the PFC sells as fast as I bought it for.
Put it this way, there's a reason why you see heaps of PowerFCs, Microshits, EMS Stingers, Wolf 3D, 4D, whatever it's up to now, etc. for sale on the used market and not many Nistunes, Haltechs, Links, etc.
Because they're ......
I see them for sale all the time but the price is still a pretty decent (not cheaper than 800 USD for ECU and controller). I havent heard much or anything about nistune (looked into it a bit, I know its cheap) and all the post I found on it were from like 2011 or older.
I'm aware of haltech and that's a pricey piece.
Like I said I wasnt looking to make big numbers and didnt really care for ethenal. Highest gas we have here is 91 octane. I'm happy with that and some minor bolt ons, my focus was still gonna be on maintaining the car. Needs some more love on that.
I assume you're American to some extent, based on the HKS SSQV BOV haha..
No idea why your people love them so much, it's annoying as bat shit.
I would invest in a decent fuel pump too, nothing too crazy. A DW300 would be decent enough for your goals, with the option of running E85 later on for mild power.
There was no need to assume I stated I was from the US in my 2nd reply. Honestly when I looked the HKS BOV is all that came up. I like it. It does what BOV do lol. I think a fuel pump is next as part of my maintenance plan. Over the weekend I'll post up a thread on my GTR. It's pretty nice but when you get down into it she needs the details.
So nistune good then? Aside from Haltech. What else can I get?
2 hours ago, Jjtxaz24 said:
I see them for sale all the time but the price is still a pretty decent (not cheaper than 800 USD for ECU and controller)...
Dang... I couldn't even sell mine for 300€ including shipping ? got that and 2 oem ECU collecting dust on a shelf, will try and put it on ebay one last time before I bin it!
Will most likely use a maxxecu (what the local tuner prefer)
Edited by K_arlstrom
Depends on budget, generally I prefer ECUs that don't use the AFM.
Generally these are good options and reasonable in price:
  • Haltech Platinum Plug-in Pro (a bit dated, but still very powerful and plenty of I/Os when you run the AUX harness)
  • Haltech Elite 2000 (no DBW and multistage engine protection, just single, need to buy patch harness OR wire in)
  • Haltech Elite 2500 (I run this, I love it - easy to tune as I self tune, need to buy patch harness OR wire in)
  • Link G4+
  • Link Fury/Xtreme (need to wire in)
  • Adaptronic M2000
  • Adaptronic 440 (they're ok, buggy but if you know how to work around them they're good value)
Then there are more mental ECUs out there like MoTec and Syvecs, but overkill.
  • Like 1
Link g4+ plugins. Lots of features and ability to do lots of different things from flex fuel, launch & traction control, DBW and cruise control.
https://www.linkecu.com/
If your spending USD$800+ on a PFC then a Link is better value.
A r32 GTR with steel turbos or single gt35 based turbo, exhaust, good injectors(ID1000/1050), Ethanol sensor, Walbro460 or DW equivalant and Current generation ecu will make a great street car with lots of potential for future upgrades.
I had bought the PFC for 600 shipped, not realizing I'd have to invest 300 more into the datalogit.
Thanks for the link.
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
