Cant start my RB25DET R33
No spark
Have tried reading the service manual but finding it slightly confusing
I believe its the ignitor
Have confirmed voltage input with the key 'on' to 6 of the plugs (i believe one is an earth so thats fine and power is coming to ignitor)
Have pulled out the ignitor and attempted to read the resistance to every combination (one side had 6 plugs and the other 7) Have read every combination and in reverse and am getting no6resistance reading (1. on multimetre)
Did read another post here with the video where in reverse there should be a resistance reading )
Should this be right in meaning my ignitor is gone? Wierd how all 6 outputs are coming as no reading
https://www.sau.com.au/forums/topic/478796-r33-no-spark-testing-ignitor/
The ignitor is 6 transistors. The inputs to it are 1x main earth (which, confusingly, lives on the same side as the outputs to the coils) and 6x trigger wires coming from the ECU. When the ECU decides it wants to fire a coil, it pulls its output low, which switches off the transistor which removes the charging power from the coil which makes the coil discharge.
It's not something that makes a lot of sense to go measuring resistances on. The test of it's function is to manually power the inputs and see what happens to the outputs. With neither plug connected, but an earth made to pin 7 on the output side, putting power on any input should make the corresponding transistor switch on, and therefore the corresponding output should have conductivity to earth.
If you look at the wiring diagram you can easily work out where the power comes from. Power to run the coil side is connected directly to the coils, and it is this power that flows through the activated transistors to earth on the output side of the ignitor). Power to "switch on" the transistors comes from the ECU and flows to the same earth on pin 7.
Im sorry but do not really get much of it
I have put the key to on and again measured to voltage at different points
At the connector going into the ignitor im getting around 9-10v
Checking the output of the ignitor im getting 0.6v
Should i be checking while cranking?
Coil packs have 0.8ohm resistance when bench tested (should i be checking the input voltage from the harness)
This is the test.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
