Hi everyone, I used to be on these forums quite a bit going back 6-10ish years ago when I had my R33 GTST (avatar) and this was a great place where I found guides on how to do everything imaginable, and really as a 19 year old with no previous mechanical knowledge that was what taught me how to work on cars.
I lost my licence being silly (well ended up on 12 month good behaviour...) so I sold the skyline and drove boring cars for a couple of years.
After about 4 years I ended up with a stock Forester XT that was only ever meant to be a bit of a fun car, but that turned into a beast as now I've done every possible bolt-on mod (big turbo, big intercooler, full exhaust, intake and heaps of smaller supporting mods) for and almost doubled it's power (127kw -> 214kw).
I also bought a motorbike to commute as fuel was adding up. Long story short we moved closer to my work again and when I listed the bike for sale, someone offered me a S1 Stagea RS4 auto awd as a swap... after thinking about it and going to inspect it we went ahead with the trade. The Stagea was definitely not in showroom condition but did have a few things done to it like a rebuilt motor which interested me and of course I saw the potential of the RB25DET :)
Anyway it's good to be back... I'll shortly go ahead and make a build journal here, which is the best place to do that? Are members galleries a used thing these days or am I better off making a thread in a specific forum?
  • Like 2
https://www.sau.com.au/forums/topic/478798-my-return/
17 hours ago, PranK said:
Welcome back!
Damn that picture reminds me so much of my stag! What awesome cars they are.
Any plans for it?
You could start a build thread for it in the appropriate section.
Thanks mate. Definitely have some plans for it once I can get it running reliably! Forged motor is one thing but fuel and battery/charging have needed some work just to keep stable... hopefully I've got it all sorted out now and once I get the starter motor swapped (died on me last week...) she should be apples until it's upgrade time.
I'm thinking a 3076 turbo, e85, 1000-1500cc injectors and a haltech ecu. Maybe the ecu first so I can get a tune going for the timebeing an get rid of some of the rich and retard feature which should liven things up a bit! The biggest issue will be having to run it as a piggyback due to the auto...
Money and time permitting I'd love to manual swap it as well because I think they look ridiculous and awesome drifting!
What would be the best section to start a build thread?
EDIT: Nevermind, I just found the "Projects" forum :)
Edited by mosquitocoils
https://www.sau.com.au/forums/topic/478798-my-return/#findComment-7916834
Welcome back to the fold. You must have been OG! Cool that you've come back.
I put my cars into a build thread: https://www.sau.com.au/forums/forum/190-projects-overhauls-and-build-ups/
I think I misuse them, but if you're doing actual work on the cars, you'll be right! :)
I love wagons (a lot for someone without a stagea anyways) so I'll be following along enthusiastically.
https://www.sau.com.au/forums/topic/478798-my-return/#findComment-7916840
Ok awesome! Made a build thread in there :)
Haha yeah it was definitely a big forum at the time. It seems to still be pretty active which is awesome!
I always liked the stags but probably wouldn't have ended up with one unless someone offered it as a trade. It can definitely get up and move though that's for sure, even on about 10psi and running super rich haha. I can only imagine at this point how it will feel with a proper tune and some more boost, should be awesome.
  • Like 2
https://www.sau.com.au/forums/topic/478798-my-return/#findComment-7916844
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
