Just saw a leak underneath my car and thought it was a transfer case leak but it was actually gear oil.. After I wiped it down and drove it for a few days it was back but dripping down on the sides.. Which led me to believe it was coming from the top of the transmission so I checked my shifter and there's a ton of gear oil leaking from it.
The last owner of the car bought one of those shitty Chinese 40$ short shifters, the one right here . It looks like when they installed it they didn't secure the shift boot onto the shifter housing I also noticed upon taking it apart I noticed it doesn't have any sort of gasket or anything.
On the Nismo shifter I think I see a gasket or two that should be used?
Is the shifter supposed to have a gasket inside of the shift housing or is it just the shift boot that is supposed to hold in the gear oil with no gaskets?
https://www.sau.com.au/forums/topic/478804-r32-gtr-shifter-leak/
lots of ways this can go wrong, primarily because the shifter goes into the transfer case, not the gearbox.
So, transfer case could have 4l of gear oil in it (not good for it, and likely to cause plenty of splashing).
Yes, the shifter boot is the primary thing keeping the transfer case oil in, secure it with a big cable tie. There should be a gasket between the housing and shift housing but that is much less likely to be a source of leak, and can just be silicone if you don't have a gasket handy.
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
