Hello fellow Wagoneers,
My S1 RS4 Stagea has recently hit the dyno, after being swapped from AWD to RWD using a CD009.
The Atessa pump has been disconnected, and the TPS signal is handled via the Adaptronic M6000 now controlling the 1UZ up front.
We're trying to set up traction control and wheel speed using the ABS sensors on all four wheels, but due to the car being RWD now, the ABS isn't outputting a signal.
The fuse isn't pulled, but the Atessa pump is disconnected (for obvious reason)
Has anyone successfully managed to  to retain factory ABS after a transmission swap? And how did you go about it?
Thanks
https://www.sau.com.au/forums/topic/478830-awd-to-rwd-stagea-abs-problems/
Put a scan tool on it, interrogate the ABS CU to find out what it is upset about, and start with fixing those things. More than likely, because ATESSA, HICAS, TCS and ABS are all mixed up together, crippling one of them can make all of them go sad. (yes, I know you don't have HICAS or TS, but you get the point, right?)
Error codes given are as follows.
1, 2, 3,4 - Wheel Speed (I believe)
75 - TPS?
53 -  Pressure switch
Has anyone ever had success tapping in to the existing ABS Sensors on the wheels, to use as a signal for aftermarket traction control?
    • I’m guess it’ll end up with a turbo
    • To install new hicas ball joints do i really need to pay for the Frenchys hicas install tool? Or can i use something like this? https://www.ebay.co.uk/itm/395524214497?_trkparms=amclksrc%3DITM%26aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D281023%2C280568%2C280618%26meid%3D4018390c9ba246f794ed58b8b19ec80a%26pid%3D101430%26rk%3D4%26rkt%3D12%26sd%3D205160403603%26itm%3D395524214497%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DCompVIDesktopATF2V2AndXaiHotClickWithCompV6WithEbertNRTRecall%26brand%3DUnbranded&_trksid=p2332490.c101430.m2460&itmprp=cksum%3A3955242144974018390c9ba246f794ed58b8b19ec80a|enc%3AAQAKAAABMDJfxvEKz%2FWsdyy97PIVwAhtkTIJPGKp%2Bu7TYjjsvNO4eN9duTRR%2FSVFYts6UXmN8tSK75ee0LypjLaKkPNQ2gkat4DyNLnViXKBVpI1%2B5fAYfWiGJa5QlqEPseqbSJUD9gVo2KSXbnmQjuPDJH4flTH2bOLSO%2FvMrLjgPDIc7vGrlKtoSauZb0q%2Fu43zLR0J8tg1z5dPMV%2FcHtnqRYXb7R7V8G%2FrQGhpY1sWtGJXc4TWc78ccs69UXnMiCqqd05ITd%2BY7Vwbq5Uzd%2FWhmiZCytO66vqDnbJn03qN%2Bin0ImF5sgbgu9uD45tXNN8cr4IWfqzIEEpaKcgqilwbTDxMkIQ4sGcgz7IhYONV017vE6P9ksZ7n%2FFVwgs3kAfMb0%2FLGjwaqhwo0yilTIjGHg9mwU%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01JMR0X9WMB8DPEX82P2P3CRXN
    • I would be lying if I said I wasn't interested in what MCM were going to do with the NC I really enjoy their banter and occasional collaborations (like Alan from TSF, Ben from BCW, or any of the Haltech guys throwing around their experience), and I have probably watched everything they have put out
    • Not yet, we basically drove it to a private road, got the logs and drove it straight back. I think I need a new passenger seat belt after the mrs squeezed the life out of it.
    • Sounds insane! 🤤🤤🤤  Do you have any vids of it driving?  A flyby would be nice!
