new to the RB engine series and skyline scene, my question is in regards to the RB25DET engines, I don't know if both of these are considered NEO version. I have attached two pictures, my question is what is the arrow pointed to in each pictures ? and why are they different from pic to pic if both engines are RB25DET. if so which would be correct from a R34 98 skyline gtt? thank you
459076338_rb25detversion.jpg.ae538cd336d18c214596880b4cdf6d08.jpg682914015_rb25detversion2.jpg.0ef8ebd1bd6425347d469cfa918a5989.jpg
Edited by JC71
no idea on the ecu #, these are just pictured I goggled to show the differences by the intake, which you refer to as traction control... so the cylinder shaped casting has traction control and the other doesn't? or different generations/version of traction control? so either could have been used in a rwd R34 98 skyline 2 door that came with the rb25det?
...maybe one of these/version was originally from a Nissan STAGEA?
or something to do with being from a 4wd or rwd version?
Edited by JC71
there are lots of variations over the 20 odd years these were made. I guess the question is why exactly do you need to know, or are you just interested?
the short blocks/ bottom ends are pretty much the same, heads were different between original and NEO, sump is different between 2wd and 4wd (since 4wd has a diff in it), and various external bits like CAS, ignitors/coils, turbo changed between years and models too.
The key difference in the NEO for aftermarket use is the improvements in the head which made them flow better and also better starting point for modifications.
This.
Traction control with 2wd no traction control with 4wd.  No telling what car they came out of but ecu number (if original) would tell the story.
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
