Does anyone have instructions / wiring ??
I've searched everywhere and what I can work out is that:
Red - 12V
Black = Gnd
Yellow is AFM Signal OUT
White is AFM signal IN
What's orange for ??
What are two trimpots on the back - some sort of adjustments I guess but what ?
Cheers,
https://www.sau.com.au/forums/topic/47884-hks-eids-wiring/
Orange will be for wiring to the throttle position sensor. It only messes with the AFM signal (clamps the voltage signal from AFM) when the throttle body is closed.
Im not sure but the trimpots on the back are for duration (seconds) and signal (volts). I cant remember exactly but basically you set it up so that when it detects the throttle body is closed then clamps the AFM signal voltage at whatever you set it to (via the trim pot) for a set period of time (via the other trimpot...lomg enough for any reversion to settle).
It took a while to get working on a friends 200SX, i would suggets playing with the duration first then tweak the voltage that you are clamping the signal at.
https://www.sau.com.au/forums/topic/47884-hks-eids-wiring/#findComment-965994
Thanks Roy - I guess the Orange to TPS would be to the variable output from the TPS (I can work that out with a multi-meter)
What do you reckon AFM IN and AFM OUT mean ??
Is AFM IN - Into the AFM or IN to the ECU ??
I'm also guessing that you cut the AFM Signal wire - and hook up the IN and the OUT ??
Just gotta work out what IN and OUT mean ? :P
Cheers,
https://www.sau.com.au/forums/topic/47884-hks-eids-wiring/#findComment-966002
Cheers,
I think the AFM IN on the EIDS is the signal wire from the AFM to the ECU. Then the EIDS out is the modified signal voltage going to the Power FC .
https://www.sau.com.au/forums/topic/47884-hks-eids-wiring/#findComment-966094
  • 1 year later...
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
    • No, I don't remember the exact reasoning (was 20 years ago!) but the cops didn't end up supplying it to us either. Actually my mother went through a similar thing recently where she was hit when stationary, flustered and didn't get address (she got plate details, name, phone and insurance company, but not address). Person who hit her blocked her number and their insurance company (naturally) would not provide any details. Her insurance company also required her to pay the at fault premium because she did not have the address, cops did not help as it is a minor civil matter (they said their only course was if the other driver had left the scene of the accident without providing any details). She only ended up getting that refunded because they happened to be insured with Suncorp and she was with APIA so same company owners. For some reason the address is critical in insurance companies recovering money from the at fault party
    • If you're driving something like an R32 through to R34, no chance of meeting Euro4. Euro4 came out in 2006, and car manufacturers back then were complaining how hard it would be to meet those regulations. Not a chance a vehicle 10 years earlier is going to be compliant.
